Activity › Forums › Avid Media Composer › Adrenaline Digitizing and logging
Posted by Martin Sterling on September 7, 2006 at 10:32 pmare there any significant differences between Avid Adrenaline and Media Composer when Digitizing and logging
G5 Dual 2.0 GHz processor, OSX.3.9
German Rubio replied 20 years ago 3 Members · 3 Replies -
Michael Hancock
September 7, 2006 at 11:52 pmI assume you mean Media Composer Adrenaline versus Media Composer Software Only. Shouldn’t be. Maybe there’s a restriction on the resolution you can capture (MC Software Only might not be able to do 1:1 without a Mojo or Adrenaline Box), but otherwise the process is the exact same. Heck, the process is the same from Xpress DV through Symphony, as far as I know. Only the available resolutions differ. I think DS is a different animal though–never had the opportunity to play on one.
Mike.
Martin Sterling
September 8, 2006 at 12:14 amThank you, very helpful.
German Rubio
September 11, 2006 at 12:46 pmI dont know if you are triying to make a batch list and then take the bin to the adrenaline.
We sometimes make the batch list offline on avid xpress dv 3.5 and save the bin onto the media composer adrenaline.
Even when the DV resolution its dv420 we are allowed to change it in the MCA, to 1:1 and then digitize.
Hope this helps!!!!
