Activity Forums Avid Media Composer Adrenalin Capture
  • Adrenalin Capture
    Posted by Jack Entonces on November 4, 2006 at 6:20 am
    I need to figure out how to capture footage from BETA
    into an Adrenaline.
    I have my settings on Component, but when I hit record button,
    I get a window that says, “the audio is not digital and does not match
    the audio” and it gives me a choice to continue or to abort.
    When I continue, nothing happens, I get a media ofline clip.
    Can someone tell me what I’m doing wrong?
    What are the settings in order to capture from Beta tape?
    Thanks.
    Tucklis replied 19 years, 9 months ago 3 Members · 2 Replies
  • Michael Phillips
    November 4, 2006 at 4:06 pm
    In the capture window there is also a menu for audio next to the video I/O. Make sure that is set correctly for the connection you are using.
    anything 24fps
  • Tucklis
    November 8, 2006 at 10:35 pm
    Otherwise go to the audio project setings and check what your input settings are set to….
