Activity Forums Adobe Premiere Pro Adobe premiere pro zoom in on my video, why is that? So annoying!
  • Adobe premiere pro zoom in on my video, why is that? So annoying!
    Posted by Marius Svendsen on March 12, 2011 at 11:26 pm
    Hello, im using premiere pro 5 and im having a problem. When i put in my
    Source clip, and then drag it down the timeline all is good until i see the video in the other window(program window?). Then its all zoomed in, i cant see the whole video picture. Very annoying and i cant figure out how to fix it. Can anybody help me? Im editing canon 5d footage, maybe its a project setting adjust?
    Kind regards,
    Marius
    Liz Johnson replied 10 years, 5 months ago 7 Members · 6 Replies
  • Todd Kopriva
    March 12, 2011 at 11:42 pm
    It sounds to me like your sequence settings don’t match the settings of your source footage. You can either create a sequence that matches the dimensions of your source footage or scale the clip within your current sequence so that it fits.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Angelo Lorenzo
    March 12, 2011 at 11:46 pm
    First of all, what are your sequence settings?
    Without knowing that, I can only suggest the following:
    1. Your program monitor may be zoomed in to 100% instead of “fit”. To correct this underneath your program monitor you will see a drop down menu. Select “fit” or any of the other options until it fits nicely on your screen.
    2. If it’s a scaling issue you can right-click on your clip in the timeline and deselect “fit to frame size”.
  • Jon Barrie
    March 14, 2011 at 10:57 am
    If you are using CS5 then you can drag the media file over the new item icon (at the bottom of the project panel) for a new sequence to be made with matching settings of the media you are using. Saves the trouble of finding the “right” sequence settings manually. 🙂
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Luigi Mario
    June 13, 2015 at 8:47 pm
    Hey Marius,
    I don’t know if you ever got your answer or not but I think that I have an answer to your problem. I ran into the same issue as well and here is what I have found. Now I use Adobe Premiere CS6 so I don’t know if this works on older versions or not:
    After you lay the video on the timeline right click it. With-in the new pop-up window there should be a selection that says: “Scale to Frame Size” Just click that and it will solve your problem!
  • Summer Tovey
    February 22, 2016 at 12:52 pm
    Luigi,
    That works perfectly – I’d been having the same problem so thank you so much for the solution!
  • Liz Johnson
    March 24, 2016 at 10:08 am
    When I right-click the clip and choose “Scale to frame size”, the quality of the video is rather terrible. I don’t know why, or how to fix it and it’s driving me crazy, can anybody help?
    And yes, it’s fit.
