Activity Forums Adobe Premiere Pro adobe premiere pro wont render
  • adobe premiere pro wont render
    Posted by Jimena Mora on June 24, 2015 at 3:39 am
    Hello:
    Im having trouble with my project, render will not start. I have tried closing premiere, restarting the computer, but nothing seems to work.
    I cannot find a solution.
    thanks
    Buddy Brett ramker replied 11 years, 2 months ago 2 Members · 1 Reply
  • Buddy Brett ramker
    June 24, 2015 at 6:47 pm
    Couple of things with Rendering. First check where your “Preview” scratch disk location is set. This is the folder Premiere writes to. If it is in a directory that doesn’t have sufficient privileges, Premiere will not be able to render. If the directory is ok, I would suggest throwing out the project folder of renders inside the Previews folder and letting it start over. Many times Premiere Jams up while trying to render due to old or existing render files.
    Hope this helps!
