Activity Forums Adobe Premiere Pro Adobe Premiere Pro CS5 PC – Changing target disk for Media Encoder
  • Adobe Premiere Pro CS5 PC – Changing target disk for Media Encoder
    Posted by Steve Mac kenzie on May 10, 2012 at 2:34 am
    It keeps trying to save encoded clips on my system drive when there are Terabytes to burn elsewhere. I am sure it is a menu I just did not see it. Thanks!
    Steve Mac kenzie replied 14 years, 3 months ago 3 Members · 3 Replies
  • John-michael Seng-wheeler
    May 10, 2012 at 4:06 am
    Um, I’m not exactly sure what you’re after here….
    You can tell it where to save the file in any number of ways… When you’re setting up the export type, or if you click on the file path listed in the queue… Seems rather simple to me. Are you talking about something else?
  • Jeff Pulera
    May 10, 2012 at 8:01 pm
    In the Adobe Media Encoder window, look for the YELLOW path name in upper half of window, which is usually the name of the SEQUENCE. Click on the that and you can then change the name and Save location as well.
    Jeff Pulera
    Safe Harbor Computers
  • Steve Mac kenzie
    May 11, 2012 at 1:29 pm
    When I set up the export type I do not see an option on where to save it. When I set up in the que there is an option but it over-rides and keeps trying to put it on my C Drive.
