Activity Forums Adobe Premiere Pro Adobe Premiere Pro CS3 Constantly Crashing on Export
  • Adobe Premiere Pro CS3 Constantly Crashing on Export
    Posted by Shaun College on January 1, 2014 at 6:48 am
    I have a project with clips totaling about 1 minute at 720,576 25fps.
    Every time I try to export I get this message:
    “Error compiling Movie”
    When starting the program, I alternately get the following:
    “Adobe Premiere Pro is running very low on system memory. Please save your project and proceed with caution”
    Sometimes this is followed by:
    “Premiere Pro has encountered an error: [….SrcPPixHandleUtilities.cpp-114]”
    Sometimes the app just freezes, or closes.
    I have the following system:
    CPU: Intel Core 2 Quad CPU Q9300 @ 2.50GHz 2.50 GHz
    RAM: 8 GB
    OS: Windows Ultimate 7 64 bit
    Free Disk Space: 267 GB
    I have been keeping an eye on the system memory – usage stays right below 4 GB.
    I’ve tried the following:
    -Cleared my %temp% file
    -Set PP Preferences to “Optimizing Rendering for Memory”
    -Copied my files into a new sequence
    -Created a new project and imported the old project
    -Reduced the number of clips
    Nothing is working.
    Roger Castillo replied 11 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Dennis Radeke
    January 1, 2014 at 12:24 pm
    Sounds like your system is still wanting memory. I would try to disable any background services that you can via task manager, certainly disable virus protection and be offline (in order to get to the root of your problem). Trash your Premiere Pro preferences and see what that gets you.
  • Shaun College
    January 1, 2014 at 5:34 pm
    Thanks for the reply.
    So 8GB is not enough to render a 70 second 720×576 video in Premier Pro? Ouch.
    Resources show at least 4GB free. I’ve already used msconfig to remove all superfluous and unnecessary services.
    I’ll certainly try offline though.
  • Dennis Radeke
    January 2, 2014 at 11:25 am
    [Shaun College]
    So 8GB is not enough to render a 70 second 720×576 video in Premier Pro? Ouch.”
    8GB is more than enough for what you describe. I was looking at the overall symptoms against what information you had provided. I also said, to trash your preferences for Premiere Pro and see if that helps.
  • Shaun College
    January 3, 2014 at 3:02 am
    I appreciate your help.
    Unfortunately, trashing my preferences made no difference.
  • James Crocker
    March 21, 2014 at 3:06 pm
    Hi Shaun.
    I have exactly the same problem. Same errors. I have only 4GB of memory however. I was thinking I should up the RAM. But looks like the problem may still remain. Did you ever find a solution? Would appreciate it so very very much. Cheers James
  • Shaun College
    March 21, 2014 at 3:45 pm
    Sorry, I never really found out what the problem was – but it certainly wasn’t due to RAM.
    I started the entire project over with new source and clips. After that, I did not have any more problems.
    My suspicion is some kind of incompatibility between one of the video clips and Adobe. They all played successfully, though, so if there was an issue, I never discovered which one.
  • James Crocker
    March 21, 2014 at 3:57 pm
    Thank you so much.
    I have video from multiple sources and was wondering if one of them might be the problem. sigh.
    Thank you again.
    Now to rebuild the project from scratch…
    Cheers
  • Roger Castillo
    February 25, 2015 at 6:57 pm
    Did your problem go away? I’m suffering from that now. When I try to export to Matrox Media Composer or Adobe Media composer… CRASH. I tried un-installing and re-installing Production Premium and I still get the same result. I also tried importing 10 sec of color bars from P2 card and creating a whole new “project” and still get the same result.
