Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro 1.5 Track Matte
Posted by Scott Williams on May 7, 2006 at 4:21 amHi all,
I’m trying to get the Track Matte effect to create a Transition between two video tracks, using an Alpha Channel as the transition. It’s not working. I went to the help menu and followed the directions exactly. I created my own transition in After Effects and that didn’t work so I tried one of the transitions that comes with Digital Juice’s Editors ToolKits and that didn’t work either. Any ideas? Am I missing something?
Thanks.Scott Williams replied 20 years, 4 months ago 3 Members · 7 Replies -
Mike Velte
May 8, 2006 at 11:45 amTransitions wont work between tracks since A/B editing died, other than using opacity fades or a black or white color matte in a superior track over the join.
Steven L. gotz
May 8, 2006 at 3:07 pmI will assume you are using a single sided transition on the end of the clip in the upper track? Most of the transitions work that way. I have come across some that acted odd, but I never investigated and just found another way.
I suggest attempting to use the transition between two clips on the same track first. On the other hand, are you sure that your video has an alpha channel to work on? Most video doesn’t.
Steven
http://www.stevengotz.com -
Scott Williams
May 8, 2006 at 11:36 pmActually I am using a video clip I created in After Effects. The clip starts out all Black and wipes to White. Using the Track Matte, found under the Keying tab in the Video Effects palette, it is supposedly possible to Transition from one video clip to another. I originally found out about this when I purchased an Editors Toolkit from Digital Juice, which came with a number of pre-made Transitions. They offer directions on their website which is exactly the same as the Help Menu in Premiere.
To apply the Track Matte key:
Add the background clip to a track.
Add the clip you want to superimpose to any track higher than the track containing the background clip. This is the clip revealed by the track matte.
On a third track, add the track matte clip.
In the Effects window, expand the Video Effects bin and then the Keying bin, and drag the Track Matte effect to the superimposed clip.
In the Effect Controls window, click the triangle next to the Track Matte name to expand it.
For the Matte option, select the video track that contains the track matte.
In the Timeline window, hide the track containing the track matte by clicking the track’s Eye icon.
Adjust other options as needed.
Composite Using
Select Matte Alpha to composite using the values in the alpha channel of the track matte. Select Matte Luma to composite using the image’s luminance values instead.I used the Luma option. Hope this helps some. I
Steven L. gotz
May 9, 2006 at 2:19 pmThat sounds correct. If you want to send me the AE project, I will give it a shot and see if it works for me. My email is on my web site.
Steven
https://www.stevengotz.com -
Scott Williams
May 9, 2006 at 4:04 pmWould you like the whole project, or just the video clip I rendered out of AE? What’s the best way to do that, ZIP?
Thanks – Scott -
Steven L. gotz
May 9, 2006 at 6:20 pmThe project is probably a lot smaller. I can export out a copy of the clip myself.
Steven
Scott Williams
May 12, 2006 at 5:36 pmI got the problem figured out with some help from Steven Gotz. I was putting the Track Matte effect on the Transition clip not the Track 2 clip. I’m glad it was something really simple and not a problem with Premiere.
Thanks again for all the great help. It’s really great having a friendly community to get advice from.
-Scott
