Activity Forums Adobe Premiere Pro Adobe premiere CS6 problem with capturing
  • Adobe premiere CS6 problem with capturing
    Posted by Otto Jibladze on May 25, 2013 at 2:32 pm
    Hello. Recently I installed Adobe premiere CS6. When I capture video from my HDR HC5 camcorder via Premiere, it saves it in mp3. Problem is in Premiere, not in camcorder, because it perfectly works with Premiere CS4 which I installed on my another computer. What Can I do? Thanks and sorry for my bad English.
    P.M. Don’t recommend me “Split” because It does not work on my Windows 7.
    Chris Tompkins replied 13 years, 4 months ago 3 Members · 4 Replies
  • Chris Tompkins
    May 25, 2013 at 4:55 pm
    How exactly are you capturing from HDR HC5 camcorder?
    Chris
  • Otto Jibladze
    May 25, 2013 at 6:46 pm
    I just connect it via Firewire, then I launch Premiere, I choose from tab section CAPTURE, then I choose HDV and there I go. This you wanted to know?
  • Ann Bens
    May 25, 2013 at 9:53 pm
    Nearly all solutions are listed in this doc below.
    Most common solution is to set firewire driver to legacy.
    https://kb2.adobe.com/cps/828/cpsid_82848.html
    Bit odd HDV split does not work.
    Something wrong with the card or the driver?
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Chris Tompkins
    May 25, 2013 at 10:06 pm
    Well done Ann, nice job.
    Chris
