Activity Forums Adobe Premiere Pro Adobe Premiere CS5.5 won’t play the project timeline
  • Adobe Premiere CS5.5 won’t play the project timeline
    Posted by Mark Robinault on September 13, 2011 at 5:54 pm
    I have never had a problem with Adobe Premiere CS5.5 until recently.
    The timeline won’t play anything, I can scrub the video and audio just fine, but it won’t play.
    I have a 12 Core Mac pro with 6GB of ram…it’s a powerful machine…I don’t understand why it should be doing this. The loop feature is not enabled. I’ve tried restarting the program, reinstalling the program, and trouble shooting the settings.
    Please help if you know anything about this issue.
    Cris Fugler replied 10 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    September 13, 2011 at 10:49 pm
    Try this solution: https://kb2.adobe.com/cps/842/cpsid_84287.html
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • James Erdman
    September 14, 2011 at 3:53 am
    Kevin,
    I have the same problem, I think…but I am on Windows 7 version of Creative Suite Production Premium. Premiere Pro imports video just fine, but when I drop into the timeline..it won’t display at all. After Effects is not affected by this. Will the same type fix work for Win version?
  • James Erdman
    September 15, 2011 at 2:24 am
    I figured it out. Problem solved.
    Nobody responded, but I am new here…..lol
  • Joel Morales
    October 9, 2011 at 11:45 pm
    Pardon me, but what exactly did you do to fix your issue? I am actually having a very similiar problem and have yet to be able to find a solution.
  • James Erdman
    October 10, 2011 at 4:38 am
    Joel,
    As it turned out..I have two graphics cards for my dual operating systems. One is an Nvidia Fermi and the other is a Radeon. Premiere was meant to run off the NVIDIA and I had accidentally switched over to the other that runs the Mac. Once I figured it out…I swapped the settings and Premiere was fine. Premiere’s Mercury acceleration (on the PC) needs that card.
    I would check your driver settings and be sure it is set correctly.
    J
  • Larry Gordon
    February 19, 2012 at 6:57 pm
    Hello All,
    I usually follow Colombo logic, so thinking about my own 48GB 24 Core
    Dual Xeon…Hmm…what just changed, I thought…
    I noticed Skype, of all things was now running in the background.
    I quit Skype and PPro began to work once more.
    I think this…if you have a webcam or Firewire device that is hogging an interupt or nagging the CPU process list it may prevent PPro from functioning correctly.
    Hope this helps and I only found out because my PPRo just did the same thing. Skype on, PPro timeline fails to respond.
  • Cris Fugler
    February 19, 2016 at 6:02 pm
    Just to add to this discussion for others who have a similar problem but not finding a solution, I found two solutions. I once found that I solved this issue by taking out a certain piece of audio. It played fine after that, and then I reinserted the audio. Still great. A second time I was working on a project, and when I un-enabled a piece of audio, it suddenly wouldn’t play for me. After a while of playing around with the timeline, I re-enabled that audio, and it worked just like before. I’m sure this is a deeper issue but it might help someone out there.
