Activity Forums Adobe Premiere Pro Adobe premiere CS5.5 multicamera
  • Adobe premiere CS5.5 multicamera
    Posted by Miloš Homola on April 1, 2012 at 2:16 pm
    Hi I read that AP can handle only 4 cameras.
    Well in my previous project I used about 20cameras in Vegas (Vegas can handle up to 32cameras)
    It was video clip with many different shots with one shooting camera and I had to edit everything at once (more convenient).
    Now I would like to use premiere in the future. But this limitedness is real problem for my work. Is there any way how to solve this?
    I dont want turn off layers and watch it separately, its painfull..
    Note:Im surprised that vegas can handle this and premiere not. So if its not possible, how can editors edit for intance this kind of video clips in the best convenient way than my.
    Tom Daigon replied 14 years, 5 months ago 4 Members · 5 Replies
  • Abhishek Kumar
    April 2, 2012 at 4:19 am
    Hey there!
    Yep, Premiere Pro is limited to 4 “live” streams at any given point in its multicam feature, which I hope they will fix with the upcoming release of CS6.
    For now, I suppose one course of action is to run multiple multicam sequences four streams at a time (I haven’t done it, so I’m not sure how effective it will be, if at all) and then put all the edits into a final sequence. It’s time consuming, but would still be faster than doing it all manually.
    As for your surprise, for years Adobe neglected Premiere but with the demise of Final Cut Pro (and the rise of iMovie Pro), that is changing for the better!
  • Al Bergstein
    April 2, 2012 at 1:52 pm
    If you need that many cameras, I think you need to stick to Vegas for a while. The good news, having used both Vegas and Pr for multi camera editing, is that Pr doesn’t crash like I’ve found Vegas does. I have never, repeat never, had my session end under Pr like what is an all to often occurrence with Vegas. We both know that Vegas continues to have stability problems, quite well documented on their forums, by people like me (G), for years now. Perhaps you’ve been lucky with your configuration and see less crashes than I did.
    My experience with Pr is that while a bit of an odd workflow, (Vegas multi cam is quite a nice fluid workflow), it does work. Now that I’ve finally got it down, it doesn’t seem too difficult (the notion of having to mark sync points is not intuitive, as in Vegas you simply slide the audio into sync, nor this weird idea of nesting mcam timelines). I’ve not needed Pluraleyes with it yet as syncing via marking points with just a couple of cameras is fine. There are things I’d like to see differently, like actually being able to see the audio waveforms better on the timeline, without constantly messing with the window sizes. (maybe with voice recognition I can just shout, “hey, open that damn window!” whenever I want the audio timeline to expand…but not sure how my wife would take to that…
    Since you have so much more camera experience than I do, (I can’t imagine using that many cameras!), you might want to play around with it if you have time, and see what you can do. Likely they will remove this limitation of multi camera in some future version,maybe even 6, and the ability to integrate with the rest of Adobe’s professional line of tools is worth the effort. There’s so much more you can get done with AEs for example, than the lame set of buggy titling tools that comes with Vegas (the NewBlue tools constantly crashed my machine after having had no problems with ProTitler). I had to go back to doing titling by starting a new timeline each time I wanted to do the simplest title beyond basic, render it out and then add it to the main timeline…sheesh. That issue is moot now.
    Good luck, and I would go to Adobe’s web site and put in a feature request for 32 camera multi camera editing.
    I’ve not tried Avid, if you are needing to get off Vegas, then you might download their trial. But as Conan’s editing team mentioned, well, you’ll have to listen to it yourself. Enjoy.
    https://www.photographybay.com/2012/03/15/adobe-premiere-pro-cs6-teased-via-conans-editors/
    Al
  • Miloš Homola
    April 2, 2012 at 6:00 pm
    Thank, you have exactly right! I have same experience with crashing in vegas, on average every 10minutes especially working in multicamera mode. So there is reason why I save my project after every action, it sucks, thats also reason why I want to move to Premiere.
    I try to suggest on adobe forum for sure, thanks
  • Miloš Homola
    April 15, 2012 at 4:12 pm
    OK CS6 will have unlimited cameras, sweet ! 🙂
  • Tom Daigon
    April 15, 2012 at 5:41 pm
    The only limit is the performance capabilities of your edit system when playing various kinds of codecs.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
