adobe premiere cs4 – crashes
Hello, i use a macbook with snow leopard, every time that i open a project on Premiere Pro cs4 the Premiere freezes when its trying to generate the videos. I’ve spend many hours searching the internet for an solution but i didn’t found anything to help me:/
Your help will be very much appreciated.here is the log when thePremiere crashes:
Date/Time: 2009-10-19 19:25:40 +0100
OS Version: 10.6.1 (Build 10B504)
Architecture: x86_64
Report Version: 6Command: Premiere Pro
Path: /Applications/Adobe Premiere Pro CS4/Adobe Premiere Pro CS4.app/Contents/MacOS/Adobe Premiere Pro CS4
Version: 4.1.0 (4.1.0)
Parent: launchd [154]PID: 794
Event: hang
Duration: 5.75s (sampling started after 2 seconds)
Steps: 37 (100ms sampling interval)Pageins: 0
Pageouts: 39Process: Adobe Premiere Pro CS4 [794]
UID: 501Process: AdobeCrashDaemon [797]
Path: /Applications/Adobe Premiere Pro CS4/Adobe Premiere Pro CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Resources/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
UID: 501Process: AirPort Base Station Agent [180]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 501Thread 5171000 DispatchQueue 1
User stack:
37 ??? (in AirPort Base Station Agent + 5344) [0x1000014e0]
37 ??? (in AirPort Base Station Agent + 70666) [0x10001140a]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x10006adc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10006b03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10006bce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100484d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5e6f3d4 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x10049e9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x10049eb28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x10049f1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x10049f6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x10049db16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 5507000
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x1004bde19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x1004bdf66]
37 ??? (in AirPort Base Station Agent + 71314) [0x100011692]
37 ??? (in AirPort Base Station Agent + 13712) [0x100003590]
37 ??? (in AirPort Base Station Agent + 71484) [0x10001173c]
37 __semwait_signal + 10 (in libSystem.B.dylib) [0x1004bf9c6]
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 60fbb7c
User stack:
37 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x1004c89f2]
Kernel stack:
37 sleep + 52 [0x486ec5]Binary Images:
0x100000000 – 0x100016fff com.apple.AirPortBaseStationAgent 1.5.4 (154.2) <73DF13C1-AF86-EC2C-9056-8D1946E607CF> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
0x100020000 – 0x100193fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x100484000 – 0x100642ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: AppleSpell [229]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID: 501Thread 507f000 DispatchQueue 1
User stack:
37 ??? (in AppleSpell + 5976) [0x100001758]
37 ??? (in AppleSpell + 6632) [0x1000019e8]
37 -[NSSpellServer run] + 72 (in Foundation) [0x10013b7f2]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100819dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10081a03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10081ace2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1004b5d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 518e7a8 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1004cf9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x1004cfb28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1004d01f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1004d06d6]
37 kevent + 10 (in libSystem.B.dylib) [0x1004ceb16]
Kernel stack:
37 kevent + 97 [0x470677]Binary Images:
0x100000000 – 0x1000a9fef com.apple.AppleSpell 1.6 (61) <9297064E-04F0-2CBF-0A16-6050010DAC3D> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
0x1000bc000 – 0x10033dfe7 com.apple.Foundation 6.6 (751)/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1004b5000 – 0x100673ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x1007cf000 – 0x100942fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: autofsd [45]
Path: /usr/libexec/autofsd
UID: 0Thread 4deb3d4 DispatchQueue 1
User stack:
37 ??? (in autofsd + 5340) [0x1000014dc]
37 ??? (in autofsd + 6461) [0x10000193d]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x1000b4dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1000b503f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1000b5ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1002f6d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 550eb7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1003109c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100310b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1003111f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1003116d6]
37 kevent + 10 (in libSystem.B.dylib) [0x10030fb16]
Kernel stack:
0x100000000 – 0x100001ff7 autofsd ??? (???) <29276FAC-AEA8-1520-5329-C75F9D453D6C> /usr/libexec/autofsd
0x10006a000 – 0x1001ddfef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1002f6000 – 0x1004b4ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: blued [44]
Path: /usr/sbin/blued
UID: 0Thread 4deb7a8 DispatchQueue 1
User stack:
37 ??? (in blued + 6232) [0x100001858]
37 ??? (in blued + 130148) [0x10001fc64]
37 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x1004fa973]
37 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x1004faa94]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10009e03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10009ece2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100d48d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 50cc3d4 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x100d629c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100d62b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x100d631f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x100d636d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100d61b16]
Kernel stack:
0x100000000 – 0x10003bfff blued ??? (???) <2155B8CF-9765-0B49-3B94-1EFF788A2A2B> /usr/sbin/blued
0x100053000 – 0x1001c6fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1004af000 – 0x100730fe7 com.apple.Foundation 6.6 (751)/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x100d48000 – 0x100f06ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: configd [14]
Path: /usr/libexec/configd
UID: 0Thread 498db7c DispatchQueue 1
User stack:
37 start + 52 (in configd) [0x100001488]
37 main + 2051 (in configd) [0x100001c9e]
37 server_loop + 72 (in configd) [0x1000024f4]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10008603f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100086ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1003c9d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 49b0000 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1003e39c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x1003e3b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1003e41f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1003e46d6]
37 kevent + 10 (in libSystem.B.dylib) [0x1003e2b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 4a413d4
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x100402e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x100402f66]
37 _io_pm_force_active_settings + 2266 (in PowerManagement) [0x100abf968]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100085dc6]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4a41b7c
User stack:
37 plugin_exec + 1440 (in configd) [0x100003c5b]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4a6f7a8
User stack:
37 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x10040d9f2]
Kernel stack:
37 sleep + 52 [0x486ec5]Thread 4dbbb7c
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x1003e394a]
Kernel stack:
37 workqueue_thread_yielded + 562 [0x4ca5c6]Binary Images:
0x100000000 – 0x100026ff7 configd ??? (???) <9ED4C5BD-86FA-DE9B-A948-8BE9ADE9005F> /usr/libexec/configd
0x10003b000 – 0x1001aefef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1003c9000 – 0x100587ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x100abc000 – 0x100acdfff com.apple.SystemConfiguration.PowerManagement 160.0.0 (160.0.0) <42FFC4FD-5D78-F476-2A4E-015951986425> /System/Library/SystemConfiguration/PowerManagement.bundle/Contents/MacOS/PowerManagementProcess: coreaudiod [129]
Path: /usr/sbin/coreaudiod
UID: 202Thread 4db83d4 DispatchQueue 1
User stack:
37 ??? (in coreaudiod + 3312) [0x100000cf0]
37 ??? (in coreaudiod + 26565) [0x1000067c5]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10012603f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100126ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1005fbd7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5505b7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1006159c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100615b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1006161f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1006166d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100614b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 4dc97a8
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x10061594a]
Kernel stack:
0x100000000 – 0x10001ffef coreaudiod ??? (???) <8580E560-986B-5336-B8B7-968C3E7C22A2> /usr/sbin/coreaudiod
0x1000db000 – 0x10024efef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1005fb000 – 0x1007b9ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: coreservicesd [55]
Path: /System/Library/CoreServices/coreservicesd
UID: 0Thread 55063d4 DispatchQueue 1
User stack:
37 ??? (in coreservicesd + 3756) [0x100000eac]
37 _CoreServicesServerMain + 522 (in CarbonCore) [0x10030c9aa]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x1009e6dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1009e703f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1009e7ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100007d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 55077a8 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1000219c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100021b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1000221f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1000226d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100020b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 562b000
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x100040e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x100040f66]
37 fmodWatchConsumer + 347 (in CarbonCore) [0x1002c136b]
37 __semwait_signal + 10 (in libSystem.B.dylib) [0x1000429c6]
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 5783b7c
User stack:
37 read + 10 (in libSystem.B.dylib) [0x100012366]
Kernel stack:
37 lo64_unix_scall + 77 [0x29d3fd]
37 unix_syscall64 + 617 [0x4ed85f]
37 read_nocancel + 158 [0x4959f5]
37 write + 312 [0x495244]
37 get_pathbuff + 3054 [0x3013cc]
37 tsleep + 105 [0x487100]
37 wakeup + 786 [0x486cd9]
37 thread_block + 33 [0x226a2b]
37 thread_block_reason + 331 [0x22699d]
37 thread_dispatch + 1949 [0x2266fe]
37 machine_switch_context + 753 [0x2a4a37]Thread 42347a8
User stack:
34 start_wqthread + 13 (in libSystem.B.dylib) [0x1000219c5]
34 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x10002194a]
Kernel stack:
34 workqueue_thread_yielded + 562 [0x4ca5c6]Binary Images:
0x100000000 – 0x100000fff coreservicesd ??? (???) <04B17F9C-7722-BE56-2850-868C11D34FF9> /System/Library/CoreServices/coreservicesd
0x100007000 – 0x1001c5ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x10025d000 – 0x10058ffef com.apple.CoreServices.CarbonCore 859.1 (859.1) <5712C4C1-B18B-88EE-221F-DA04A8EDA029> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x10099c000 – 0x100b0ffef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: cupsd [792]
Path: /usr/sbin/cupsd
UID: 0Thread 439a3d4 DispatchQueue 1
User stack:
37 ??? (in cupsd + 4292) [0x18bb0a0c4]
37 ??? (in cupsd + 108449) [0x18bb237a1]
37 kevent + 10 (in libSystem.B.dylib) [0x18c20ab16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 5f5b7a8 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x18c20b9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x18c20bb28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x18c20c1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x18c20c6d6]
Kernel stack:
37 kevent + 97 [0x470677]Thread 61e93d4
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x18c22ae19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x18c22af66]
37 ??? (in cupsd + 267265) [0x18bb4a401]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x18bbdcdc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x18bbdd03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x18bbddce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x18c1f1d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Binary Images:
0x18bb09000 – 0x18bb61fef cupsd ??? (???)/usr/sbin/cupsd
0x18bb92000 – 0x18bd05fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x18c1f1000 – 0x18c3afff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: cvmsServ [140]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
UID: 0Thread 5a633d4 DispatchQueue 1
User stack:
37 ??? (in cvmsServ + 4100) [0x100001004]
37 ??? (in cvmsServ + 23081) [0x100005a29]
37 mach_msg_server + 539 (in libSystem.B.dylib) [0x10033638e]
37 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x1002b8d86]
Kernel stack:
0x100000000 – 0x100008fff cvmsServ ??? (???) <8B29F0EA-273E-D990-D755-F64A6773BF83> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
0x1002b8000 – 0x100476ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: DirectoryService [11]
Path: /usr/sbin/DirectoryService
UID: 0Thread 3de03d4 DispatchQueue 1
User stack:
37 start + 52 (in DirectoryService) [0x10000daac]
37 main + 3086 (in DirectoryService) [0x10000e6c2]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100999dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10099a03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10099ace2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100c5ed7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 49b0b7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x100c789c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100c78b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x100c791f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x100c796d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100c77b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 4a6f000 DispatchQueue 6
User stack:
37 _dispatch_worker_thread2 + 231 (in libSystem.B.dylib) [0x100c791e9]
37 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x100c9acf6]
37 syscall + 10 (in libSystem.B.dylib) [0x100c9b2e6]
Kernel stack:
37 sleep + 52 [0x486ec5]Thread 498d3d4
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x100c97e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x100c97f66]
37 DSLThread::_RunWrapper(void*) + 67 (in DirectoryServiceCore) [0x100c4734b]
37 DSCThread::Run() + 36 (in DirectoryServiceCore) [0x100c470ac]
37 CPluginRunLoopThread::ThreadMain() + 150 (in DirectoryService) [0x10001d25c]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4dc9b7c
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x100c7894a]
Kernel stack:
0x100000000 – 0x100120fff DirectoryService ??? (???)/usr/sbin/DirectoryService
0x10094f000 – 0x100ac2fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x100c3f000 – 0x100c50fff com.apple.DirectoryServiceCore.Framework 3.6 (621)/System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
0x100c5e000 – 0x100e1cff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: diskarbitrationd [18]
Path: /usr/sbin/diskarbitrationd
UID: 0Thread 4d55b7c DispatchQueue 1
User stack:
37 ??? (in diskarbitrationd + 4064) [0x100000fe0]
37 ??? (in diskarbitrationd + 32876) [0x10000806c]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100071dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10007203f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100072ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100710d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4d553d4 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x10072a9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x10072ab28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x10072b1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x10072b6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100729b16]
Kernel stack:
0x100000000 – 0x10001bfef diskarbitrationd ??? (???)/usr/sbin/diskarbitrationd
0x100027000 – 0x10019afef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x100710000 – 0x1008ceff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: diskimages-helper [677]
Path: /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
UID: 501Thread 5a637a8 DispatchQueue 1
User stack:
37 ??? (in diskimages-helper + 17028) [0x100004284]
37 ??? (in diskimages-helper + 17713) [0x100004531]
37 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x10027aa94]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x100faf03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100fafce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100c4ad7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 81b63d4 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x100c649c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100c64b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x100c651f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x100c656d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100c63b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 5a61000
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x100c83e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x100c83f66]
37 __NSThread__main__ + 1429 (in Foundation) [0x10023ff65]
37 ??? (in diskimages-helper + 40566) [0x100009e76]
37 ??? (in diskimages-helper + 43318) [0x10000a936]
37 DI_kextDriveGetRequest + 41 (in DiskImages) [0x1000ece5f]
37 IOConnectCallStructMethod + 50 (in IOKit) [0x10062cb2b]
37 IOConnectCallMethod + 325 (in IOKit) [0x10062caa8]
37 io_connect_method + 490 (in IOKit) [0x10066d724]
Kernel stack:
37 lo64_mach_scall + 77 [0x29d44d]
37 thread_setuserstack + 405 [0x2922ba]
37 mach_msg_overwrite_trap + 274 [0x216497]
37 ipc_kmsg_send + 111 [0x210234]
37 ipc_kobject_server + 244 [0x21d09c]
37 iokit_server_routine + 4669 [0x28421d]
37 is_io_connect_method + 467 [0x5633be]
37 IOUserClient::externalMethod(unsigned int, IOExternalMethodArguments*, IOExternalMethodDispatch*, OSObject*, void*) + 894 [0x562b44]
37 shim_io_connect_method_structureI_structureO + 350 [0x561a44]
37 com.apple.driver.DiskImages 281 + 11873 [0x2eb2be61]
37 com.apple.driver.DiskImages 281 + 6846 [0x2eb2aabe]
37 semaphore_wait + 58 [0x22a154]
37 semaphore_destroy + 703 [0x229e5e]
37 machine_switch_context + 753 [0x2a4a37]Binary Images:
0x100000000 – 0x100053fff diskimages-helper ??? (???) <5ECF8BCA-E232-9C9A-338E-ECD549A98747> /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
0x1000d2000 – 0x1001d2fef com.apple.DiskImagesFramework 10.6 (281) <8C1B230C-AE15-4F19-F5BB-ADCBFC136E08> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x10022f000 – 0x1004b0fe7 com.apple.Foundation 6.6 (751)/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x100628000 – 0x100685fef com.apple.framework.IOKit 2.0 (???) <65AA6170-12E3-BFB5-F982-E0C433610A1F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x100c4a000 – 0x100e08ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x100f64000 – 0x1010d7fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: distnoted [15]
Path: /usr/sbin/distnoted
UID: 1Thread 4a6fb7c DispatchQueue 1
User stack:
37 ??? (in distnoted + 3620) [0x100000e24]
37 ??? (in distnoted + 3717) [0x100000e85]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x10004edc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10004f03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10004fce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100290d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4a41000 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1002aa9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x1002aab28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1002ab1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1002ab6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x1002a9b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 4a1e7a8
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x1002aa94a]
Kernel stack:
0x100000000 – 0x100000fff distnoted ??? (???)/usr/sbin/distnoted
0x100004000 – 0x100177fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x100290000 – 0x10044eff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: Dock [158]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
UID: 501Thread 5e2d7a8 DispatchQueue 1
User stack:
37 ??? (in Dock + 225848) [0x100037238]
37 ??? (in Dock + 525059) [0x100080303]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1013a103f]
30 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1013a1ce2]
30 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1007d1d7a]
7 __CFRunLoopRun + 4413 (in CoreFoundation) [0x1013a264d]
7 __CFRunLoopDoSource1 + 356 (in CoreFoundation) [0x1013c9f84]
7 mshPerform + 11 (in HIServices) [0x1026176b1]
7 ??? (in Dock + 46736) [0x10000b690]
7 ??? (in Dock + 359518) [0x100057c5e]
7 ??? (in Dock + 72789) [0x100011c55]
7 ??? (in Dock + 279274) [0x1000442ea]
7 ??? (in Dock + 208881) [0x100032ff1]
7 ??? (in Dock + 212824) [0x100033f58]
7 ??? (in Dock + 214514) [0x1000345f2]
7 _HandlePopUpMenuSelection7 + 665 (in HIToolbox) [0x104b72823]
7 PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1651 (in HIToolbox) [0x104b72530]
5 TrackMenuCommon(MenuSelectData&, unsigned char*) + 3355 (in HIToolbox) [0x104a4ec10]
5 IsUserStillTracking(MenuSelectData*, unsigned char*) + 175 (in HIToolbox) [0x104a61ea5]
5 ReceiveNextEventCommon + 310 (in HIToolbox) [0x104a17a53]
5 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x104a17c4e]
5 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1013a103f]
5 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1013a1ce2]
5 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1007d1d7a]
2 TrackMenuCommon(MenuSelectData&, unsigned char*) + 3460 (in HIToolbox) [0x104a4ec79]
1 SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 474 (in HIToolbox) [0x104a6763e]
1 FlashFeedback(MenuSelectData*) + 131 (in HIToolbox) [0x104a6788b]
1 HIView::SimulateClick(short, unsigned int, short*) + 167 (in HIToolbox) [0x104a67993]
1 SendEventToEventTargetWithOptions + 51 (in HIToolbox) [0x1049f0357]
1 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 395 (in HIToolbox) [0x1049f04e6]
1 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1002 (in HIToolbox) [0x1049f0f97]
1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1700 (in HIToolbox) [0x104a01be4]
1 HIView::SimulateClickSelf(short, unsigned int, short*) + 94 (in HIToolbox) [0x104a67aac]
1 SendControlSimulateHit(HIView*, short, unsigned int, short*) + 150 (in HIToolbox) [0x104a67bf4]
1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1842 (in HIToolbox) [0x104a01c72]
1 HIStandardMenuView::SimulateHitSelf(short, unsigned int, short*) + 188 (in HIToolbox) [0x104a67cf6]
1 HIMenuView::SimulateHitSelf(short, unsigned int, short*) + 160 (in HIToolbox) [0x104a67dea]
1 RunCurrentEventLoopInMode + 234 (in HIToolbox) [0x104a17beb]
1 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1013a103f]
1 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1013a1ce2]
1 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1007d1d7a]
1 SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 839 (in HIToolbox) [0x104a677ab]
1 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x104a17c4e]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5dfdb7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1007eb9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x1007ebb28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1007ec1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1007ec6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x1007eab16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 610d7a8
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x10080ae19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x10080af66]
35 ??? (in Dock + 273834) [0x100042daa]
35 __semwait_signal + 10 (in libSystem.B.dylib) [0x10080c9c6]
1 clock_sleep_trap + 10 (in libSystem.B.dylib) [0x1007d1e6a]
1 ??? (in Dock + 274005) [0x100042e55]
1 ??? (in Dock + 22125) [0x10000566d]
1 ??? (in Dock + 32263) [0x100007e07]
1 ??? (in Dock + 34680) [0x100008778]
1 CGSSetBackgroundEventMaskAndShape + 213 (in CoreGraphics) [0x101b6a7ed]
1 _CGSSetBackgroundEventMaskAndShape + 131 (in CoreGraphics) [0x1019ece13]
Kernel stack:
35 semaphore_wait_continue + 0 [0x229b17]
1 lo64_mach_scall + 77 [0x29d44d]
1 thread_setuserstack + 405 [0x2922ba]
1 clock_sleep_trap + 407 [0x219edd]
1 thread_block + 33 [0x226a2b]
1 thread_block_reason + 331 [0x22699d]
1 thread_dispatch + 1949 [0x2266fe]
1 machine_switch_context + 753 [0x2a4a37]
1 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4a11b7c
User stack:
33 start_wqthread + 13 (in libSystem.B.dylib) [0x1007eb9c5]
33 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x1007eb94a]
Kernel stack:
33 workqueue_thread_yielded + 562 [0x4ca5c6]Thread 60fb7a8
User stack:
32 start_wqthread + 13 (in libSystem.B.dylib) [0x1007eb9c5]
32 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x1007eb94a]
Kernel stack:
32 workqueue_thread_yielded + 562 [0x4ca5c6]Binary Images:
0x100000000 – 0x10016ffe7 com.apple.dock 1.7 (751)/System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
0x1007d1000 – 0x10098fff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x101356000 – 0x1014c9fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x10196e000 – 0x1020605d7 com.apple.CoreGraphics 1.535.5 (???) <6599C41F-2D50-5E04-44E4-44FA90E022B5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x1025df000 – 0x102630fe7 com.apple.HIServices 1.8.0 (???) <113EEB8A-8EC6-9F86-EF46-4BA5C2CBF77C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x1049ea000 – 0x104ce7fef com.apple.HIToolbox 1.6.0 (???) <870B39B2-55BD-9C82-72EB-2E3470BD0E14> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolboxProcess: dynamic_pager [39]
Path: /sbin/dynamic_pager
UID: 0Thread 49b07a8 DispatchQueue 1
User stack:
37 ??? [0x1000013ec]
37 ??? [0x1000023eb]
37 ??? [0x100001cae]
37 ??? [0x100001a30]
37 ??? [0x10000198f]
37 ??? [0x100312d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Process: FanControlDaemon [138]
Path: /Library/StartupItems/FanControlDaemon/FanControlDaemon
UID: 0Process: Finder [160]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
UID: 501Thread 5a60000 DispatchQueue 1
User stack:
37 ??? (in Finder + 22172) [0x10000569c]
37 ??? (in Finder + 22233) [0x1000056d9]
37 NSApplicationMain + 364 (in AppKit) [0x102630798]
37 -[NSApplication run] + 395 (in AppKit) [0x102637a7d]
37 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x102671e89]
37 _DPSNextEvent + 718 (in AppKit) [0x102672520]
37 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x10135090c]
37 ReceiveNextEventCommon + 310 (in HIToolbox) [0x101350a53]
37 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x101350c4e]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x101ff103f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x101ff1ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x101c89d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 562b7a8 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x101ca39c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x101ca3b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x101ca41f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x101ca46d6]
37 kevent + 10 (in libSystem.B.dylib) [0x101ca2b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 40e2b7c
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x101ca394a]
Kernel stack:
37 workqueue_thread_yielded + 562 [0x4ca5c6]Thread 4a123d4
User stack:
Kernel stack:
37 workqueue_thread_yielded + 562 [0x4ca5c6]Thread 50ccb7c
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x101cc2e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x101cc2f66]
37 PrivateMPEntryPoint + 63 (in CarbonCore) [0x10450ae2d]
37 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 514 (in DesktopServicesPriv) [0x10045aaa4]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x101ff0dc6]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5170000
User stack:
37 ??? (in Finder + 25129) [0x100006229]
37 ??? (in Finder + 25335) [0x1000062f7]
37 ??? (in Finder + 175088) [0x10002abf0]
37 ??? (in Finder + 175182) [0x10002ac4e]
37 semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x101c89dda]
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 61e9b7c
User stack:
37 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x101ccd9f2]
Kernel stack:
0x100000000 – 0x1003a9fff com.apple.finder 10.6 (10.6) <42AD4F20-EE5F-148A-7AD9-608E11F8A8A4> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
0x100459000 – 0x10053dff7 com.apple.DesktopServices 1.5.1 (1.5.1) <65D7E707-DBCA-5752-78EC-351DC88F3AE8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x101323000 – 0x101620fef com.apple.HIToolbox 1.6.0 (???) <870B39B2-55BD-9C82-72EB-2E3470BD0E14> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x101c89000 – 0x101e47ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x101fa6000 – 0x102119fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x10262e000 – 0x103022fe7 com.apple.AppKit 6.6.1 (1038.2)/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x104504000 – 0x104836fef com.apple.CoreServices.CarbonCore 859.1 (859.1) <5712C4C1-B18B-88EE-221F-DA04A8EDA029> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCoreProcess: Folder Actions Dispatcher [184]
Path: /System/Library/CoreServices/Folder Actions Dispatcher.app/Contents/MacOS/Folder Actions Dispatcher
UID: 501Thread 62193d4 DispatchQueue 1
User stack:
37 ??? (in Folder Actions Dispatcher + 4636) [0x10000121c]
37 NSApplicationMain + 364 (in AppKit) [0x1009ca798]
37 -[NSApplication run] + 395 (in AppKit) [0x1009d1a7d]
37 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x100a0be89]
37 _DPSNextEvent + 718 (in AppKit) [0x100a0c520]
37 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x1019f390c]
37 ReceiveNextEventCommon + 310 (in HIToolbox) [0x1019f3a53]
37 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x1019f3c4e]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10038b03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x10038bce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100023d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 648ab7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x10003d9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x10003db28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x10003e1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x10003e6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x10003cb16]
Kernel stack:
0x100000000 – 0x100012ff7 com.apple.FolderActionsDispatcher 1.0.1 (1.0.1) <7C7173BB-48CF-32B2-2AD7-3C9F09B089D0> /System/Library/CoreServices/Folder Actions Dispatcher.app/Contents/MacOS/Folder Actions Dispatcher
0x100023000 – 0x1001e1ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x100340000 – 0x1004b3fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1009c8000 – 0x1013bcfe7 com.apple.AppKit 6.6.1 (1038.2)/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x1019c6000 – 0x101cc3fef com.apple.HIToolbox 1.6.0 (???) <870B39B2-55BD-9C82-72EB-2E3470BD0E14> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolboxProcess: fontd [162]
Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
UID: 501Thread 5dfd3d4 DispatchQueue 1
User stack:
37 ??? (in fontd + 16156) [0x100003f1c]
37 main_handler + 3893 (in libATSServer.dylib) [0x100093648]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100acddc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x100ace03f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100acece2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1000eed7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5e2d000 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1001089c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100108b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1001091f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1001096d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100107b16]
Kernel stack:
0x100000000 – 0x100003fff fontd ??? (???)/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
0x10000a000 – 0x1000befff libATSServer.dylib ??? (???) <0D056144-BCD2-6806-E69E-B94A99054783> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
0x1000ee000 – 0x1002acff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x100a83000 – 0x100bf6fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: fseventsd [37]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
UID: 0Thread 498d7a8 DispatchQueue 1
User stack:
37 ??? (in fseventsd + 5580) [0x1000015cc]
37 ??? (in fseventsd + 8784) [0x100002250]
37 mach_msg_server + 539 (in libSystem.B.dylib) [0x10036438e]
37 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x1002e6d86]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5171b7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1003009c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100300b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1003011f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1003016d6]
37 kevent + 10 (in libSystem.B.dylib) [0x1002ffb16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 51363d4
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x10031fe19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x10031ff66]
37 ??? (in fseventsd + 39181) [0x10000990d]
37 ??? (in fseventsd + 38436) [0x100009624]
37 __semwait_signal + 10 (in libSystem.B.dylib) [0x1003219c6]
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 51703d4
User stack:
37 ??? (in fseventsd + 28956) [0x10000711c]
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 51707a8
User stack:
37 read + 10 (in libSystem.B.dylib) [0x1002f1366]
Kernel stack:
37 machine_switch_context + 753 [0x2a4a37]Thread 5170b7c
User stack:
37 ??? (in fseventsd + 26019) [0x1000065a3]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100060dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10006103f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100061ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1002e6d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5c893d4
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 5f15b7c
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 60e67a8
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 60eb3d4
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 60f0000
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 60f07a8
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Thread 6212b7c
User stack:
37 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x10030094a]
Kernel stack:
37 workqueue_thread_yielded + 562 [0x4ca5c6]Thread 648a7a8
User stack:
Kernel stack:
37 semaphore_wait_continue + 0 [0x229b17]Binary Images:
0x100000000 – 0x10000ffff fseventsd ??? (???) <4C5AA39F-F2D2-F6EB-5A3B-AF38B8000DE9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
0x100016000 – 0x100189fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1002e6000 – 0x1004a4ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: Google Notifier [188]
Path: /Applications/Google Notifier.app/Contents/MacOS/Google Notifier
UID: 501Process: hdiejectd [602]
Path: /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
UID: 0Thread 80543d4 DispatchQueue 1
User stack:
37 ??? (in hdiejectd + 5208) [0x100001458]
37 ??? (in hdiejectd + 5594) [0x1000015da]
37 ??? (in hdiejectd + 6049) [0x1000017a1]
37 ??? (in hdiejectd + 7196) [0x100001c1c]
37 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x10013d973]
37 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x10013da94]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10086203f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100862ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1004fdd7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 3f7e000 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1005179c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100517b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1005181f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1005186d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100516b16]
Kernel stack:
0x100000000 – 0x100008fff hdiejectd ??? (???) <2FA6B74B-53E0-0572-6114-6984C84B20AB> /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
0x1000f2000 – 0x100373fe7 com.apple.Foundation 6.6 (751)/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1004fd000 – 0x1006bbff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x100817000 – 0x10098afef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: hidd [36]
Path: /usr/libexec/hidd
UID: 0Thread 4dbb000 DispatchQueue 1
User stack:
37 ??? (in hidd + 3756) [0x100000eac]
37 ??? (in hidd + 3822) [0x100000eee]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x10030fd7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 51367a8 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1003299c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100329b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x10032a1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x10032a6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100328b16]
Kernel stack:
0x100000000 – 0x100000fff hidd ??? (???)/usr/libexec/hidd
0x10030f000 – 0x1004cdff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: iChatAgent [202]
Path: /System/Library/Frameworks/IMCore.framework/iChatAgent.app/Contents/MacOS/iChatAgent
UID: 501Thread 610db7c DispatchQueue 1
User stack:
37 start + 52 (in iChatAgent) [0x100001764]
37 main + 286 (in iChatAgent) [0x10000188a]
37 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x10013b973]
37 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x10013ba94]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x1008d803f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x1008d8ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x100573d7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 5e2db7c DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x10058d9c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x10058db28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x10058e1f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x10058e6d6]
37 kevent + 10 (in libSystem.B.dylib) [0x10058cb16]
Kernel stack:
0x100000000 – 0x10000ffff com.apple.iChatAgent 5.0 (741) <121018FA-D3CA-0415-636D-F978AC8C7524> /System/Library/Frameworks/IMCore.framework/iChatAgent.app/Contents/MacOS/iChatAgent
0x1000f0000 – 0x100371fe7 com.apple.Foundation 6.6 (751)/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x100573000 – 0x100731ff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
0x10088d000 – 0x100a00fef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundationProcess: IJEPWAgent [182]
Path: /Library/Printers/EPSON/InkjetPrinter/EPW/IJEPWAgent.app/Contents/MacOS/IJEPWAgent
UID: 501Process: ImporterProcessServer [800]
Path: /Applications/Adobe Premiere Pro CS4/Adobe Premiere Pro CS4.app/Contents/ImporterProcessServer.app/Contents/MacOS/ImporterProcessServer
UID: 501Process: KernelEventAgent [34]
Path: /usr/sbin/KernelEventAgent
UID: 0Thread 4dbb3d4 DispatchQueue 1
User stack:
37 start + 52 (in KernelEventAgent) [0x100001174]
37 main + 1130 (in KernelEventAgent) [0x1000030aa]
37 CFRunLoopRun + 70 (in CoreFoundation) [0x100056dc6]
37 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x10005703f]
37 __CFRunLoopRun + 2002 (in CoreFoundation) [0x100057ce2]
37 mach_msg_trap + 10 (in libSystem.B.dylib) [0x1002fcd7a]
Kernel stack:
37 ipc_mqueue_receive_continue + 0 [0x2104e0]Thread 4a6f3d4 DispatchQueue 2
User stack:
37 start_wqthread + 13 (in libSystem.B.dylib) [0x1003169c5]
37 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x100316b28]
37 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x1003171f6]
37 _dispatch_queue_invoke + 195 (in libSystem.B.dylib) [0x1003176d6]
37 kevent + 10 (in libSystem.B.dylib) [0x100315b16]
Kernel stack:
37 kevent + 97 [0x470677]Thread 507f3d4
User stack:
37 thread_start + 13 (in libSystem.B.dylib) [0x100335e19]
37 _pthread_start + 331 (in libSystem.B.dylib) [0x100335f66]
37 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x1003409f2]
Kernel stack:
0x100000000 – 0x100006ff7 KernelEventAgent ??? (???) <20952F40-244C-DE8B-B7BA-05B8118647CF> /usr/sbin/KernelEventAgent
0x10000c000 – 0x10017ffef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1002fc000 – 0x1004baff7 libSystem.B.dylib ??? (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylibProcess: kextd [10]
Path: /usr/libexec/kextd
UID: 0Thread 3de0000 DispatchQueue 1
User stack:
37 ??? (in kextd + 5608) [0x1000015e8]
37 ??? (in kextd + 9541) [0x100002545]
