Activity Forums Adobe Premiere Pro Adobe Premier Pro Install
  • Adobe Premier Pro Install
    Posted by Griz13 on March 16, 2006 at 1:21 am
    I’m trying to install premier pro 2 from a dvd, and after the initial loading plaques, right after I choose the language and just as the install plaque appears, I get a C++ runtime error, saying that “this program has requested the Runtime to terminate it in an unusual way”… and the setup cancels.
    any suggestions?
    Thank you in advance.
    Griz13 replied 20 years, 5 months ago 3 Members · 6 Replies
  • Aanarav Sareen
    March 16, 2006 at 4:53 am
    Copy all the files from the disc to the computer’s harddrive and run setup.exe. It should work.
  • Mike Velte
    March 16, 2006 at 12:11 pm
    I just went down that road…as Aanarav suggested, copy the installation files to the root directory of C drive, not to My Documents.
  • Griz13
    March 18, 2006 at 5:21 am
    ok… I transferred the files to my harddrive, but now when i start the install, it asks me for the language, I select English, I see a brief flash of “preparing to install”, then nothing.
    I’m confused…
    and thank you for your help.
  • Mike Velte
    March 18, 2006 at 12:42 pm
    Are you logged in as Administrator?
  • Griz13
    March 20, 2006 at 12:47 am
    I’m the only one authorized for this pc… There’s only one profile, and that’s mine, and that profile has all admin priviledges.
  • Griz13
    March 20, 2006 at 2:15 am
    I don’t know if this has anything to do with it, but I did have the trial version installed before I tried to install this version.
    The trial version said that I needed to uninstall it before I installed the full version of Premiere Pro 2.
    Also, I have 1.5 installed right now… but as I understand it, Premier 2 is a parallel install, and shouldn’t have any conflict with 1.5.
    At least, that’s the way we have it at work… both 1.5 and 2 on the same comp… and they both work great.
