Activity › Forums › Adobe Premiere Pro › Adobe Premier Audio Problem
Charles Cunliffe
June 10, 2012 at 8:29 pmI found Speakers in set up on 7 surround rather then 2 speakers, sound echo solved, maybe this is it, gonna work on my film now!!!!!
Charles Cunliffe
June 12, 2012 at 10:00 pmSO here we go, I cannot leave this unresolved for that one person out there that runs into the same thing. When I reopened the project in the newly established reloaded Premier, I got a message that the scratch disks I had set up were unavailable. So I thought, hmmm, maybe there has been a problem with my scratch hard disks, (Separate internal SATA drive) so I changed the scratch disk location to another drive and everything worked fine. Been editing for a few days now without any problems. Only took me 5 months to figure it out.
Tom Daigon
June 12, 2012 at 10:24 pmWell, better late then never 😀
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
Charles Cunliffe
June 13, 2012 at 5:34 amHi Ryan and others, bad news. Scratchy Audio, then “NVIDIA OPEN GL driver detected a problem with display driver and cannot continue” then blue screen…..suggesting I go into advanced BIOS and disable caching and shadowing options…..
I have added no additional programs since the cleaninstall just to keep the issue clear…..the only thing I did not do was look for the nvidia drive update as last time I tried, the Nvidia 285 was not on the list.
Any suggestions from the group…?
Can a video card issue cause this kind of issue with sound?
That Nvidia card wernt cheap. -
Charles Cunliffe
June 13, 2012 at 4:55 pmFound a number of folks on the nvidia site that were having similar problems to mine. The fact that the blue screen, lock up and the Nvidia driver error code happened at the same time was a clue, so I went searching that code, they suggested going to my nvidia control panel and changing a setting under “manage 3d settings / Global Setting / Power management mode / to Maximum Performance Preferred.
So far so good. Things are working…We’ll see.
Another person suggested uninstall of driver and reinstall in safe mode. -
Charles Cunliffe
June 22, 2012 at 2:34 amWell here we go. The latest was that I spent a 1/2 day on the NVIDIA GEFORCE 285 web site and determined that if I go into NVIDIA control Panel, under manage 3d settings and change the Global settings under the power management mode from Adaptive to prefer maximum performance that my problem would be solved. So I did and it worked for 2 days I edited my six month late documentary without issue. Then I installed my CS6 updated my nvidia drivers, which I had to do the get Mercury Playback support, went in and changed that setting stated above back to Prefer Max Performance, and whala, garbled audio, lock up, Blue Screen Crash Dump crash…Twice in a row.
If you think you are getting tired of this imagine how I must feel. Does NVIDIA or ADOBE ever actually read the forums to see the problems we are having. If I were a production house I would have had to throw out my PC, buy all MAC and load Final Cut months ago just to survive.
This is so ridiculous! Any suggestions out there….
BTW I have not installed any other programs after CS6 except required things like Java and Adobe Flash Player…..H_E_L_P
Charles Cunliffe
June 22, 2012 at 2:36 amWell here we go. The latest was that I spent a 1/2 day on the NVIDIA GEFORCE 285 web site and determined that if I go into NVIDIA control Panel, under manage 3d settings and change the Global settings under the power management mode from Adaptive to prefer maximum performance that my problem would be solved. So I did and it worked for 2 days I edited my six month late documentary without issue. Then I installed my CS6 updated my nvidia drivers, which I had to do the get Mercury Playback support, went in and changed that setting stated above back to Prefer Max Performance, and whala, garbled audio, lock up, Blue Screen Crash Dump crash…Twice in a row.
Charles Cunliffe
June 27, 2012 at 2:10 pmThis 3d setting did not solve the problem. After months of trying and working on tech support, I finally got the advice to run a stress test on the CPU and Video Card. I had no idea there was such a thing. At any rate , looks like a motherboard problem, machine is on a truck back to manufacturer, hope they can solve it….Thankfully under warranty.
Thanks for all of your help and attention to this matter. I’ll try and post when there is a clear victory.
Charlie
