Activity Forums Adobe Premiere Pro Adobe – Please us the ability to have multiple projects open at one time (as done in FCP)
  • Adobe – Please us the ability to have multiple projects open at one time (as done in FCP)
    Posted by Bryce Hoover on December 3, 2014 at 4:06 pm
    Adobe,
    I don’t know if you read these forums.
    I have requested this feature be added through the Feature Request portal on your website.
    I also request it here, for the benefit of others, and for additional exposure, and because I’m desperate.
    PLEASE give me (and the collective ME) the ability to have multiple projects open at the same time.
    For the last 9 years, I’ve been editing on FCP. Before that it was only Avid. One of the features that I quickly embraced and loved about FCP was the ability to have multiple projects open at the same time, move between them, make changes to each one and save them all.
    In my current job, I finish promos for a cable network. There are 9 producer/editors that all send their projects to me to color correct, add graphics, send to audio, fix technical issues, export, etc. Once they “send” it to me, they don’t touch it again until there’s a revision at a later date (i.e. schedule change). I normally work on between 3 (on a slow day) and 10 (on a busy day) projects every day. Some are single :10 spots, some are multiple :10 :20, and:30 spots in a project. I have a project template that I also use and leave up all day.
    At any given time, these multiple projects are at different stages of finishing. Some are finished except for final audio mix, some are color corrected but need additional graphics and to be sent to audio, some are totally finished and waiting for final approval viewing before export, you get the idea. When I get the audio back, I drag it in (or import it) to the project, add it to the timeline, lock tracks, then go back to what I was working on (in a different project) until the approval person is ready to view the finished spot(s). When approval time comes, I go through many projects, hoping from one to the other with a click of the sequence tab. It’s fast and efficient. If there’s a small change, I make it on the spot, save, then move to the next sequence from a different project. After approval, I export all of the approved and post on the traffic FTP server. That’s basically the workflow that we’ve established and it works like a well oiled machine. All of that to help make my case for why I need the ability to have multiple projects open at the same time.
    We’re still editing on FCP but are headed to CC very shortly. I dread the day we’re completely CC because of the added steps and time and frustration that comes with going back to the old Avid way of working in different projects, it’s incredibly inefficient.
    Adobe, you’ve taken most of the good things about FCP and made them better in your current product.
    Why did you leave out the ability to have multiple projects open at one time?
    All of the work arounds I’ve seen just create more steps, more work, and make things way more complicated.
    Importing sequences into an approval project will not work because I’m often asked to make changes on the spot. Those changes won’t update in the main project because I’m in an approval project. This creates another sequence to manage and reimport back into it’s main project, and doing this for 3-10 projects is just insane and unnecessary.
    Opening multiple instances of PP, one for each project, seems like it would tax the system resources and hardware beyond what it can handle for realtime playback without glitching. Plus, I’m not sure the Kona 3 would know what to do with 8 copies of PP open at one time.
    I hope this all makes since and effectively get’s my point across.
    Fellow editors, please don’t tell me that I don’t need or shouldn’t have multiple projects open at one time.
    That’s not constructive and doesn’t help.
    Each workflow is unique and the workflow we have works and works well.
    I do need this ability and telling me I shouldn’t work this way just exposes ignorance and arrogance on your part and nobody wants that.
    My workflow doesn’t involve sharing projects. It’s more of a hand-off workflow.
    Once I have a project, it’s totally mine.
    -bh
    Monika Pul replied 10 years, 1 month ago 11 Members · 19 Replies
  • 19 Replies
  • Scott Davis
    December 3, 2014 at 4:33 pm
  • Bryce Hoover
    December 3, 2014 at 4:51 pm
    Scott,
    I was hopeful as I watched.
    However… that work around doesn’t allow for changes to the second project sequence that I’ve opened in the Media Browser, it’s read-only and it’s only viewable in the source window (which I’m guessing won’t play out on the Kona? – not really sure about that part). This work around allows “access to content without risking modifying it”.
    What I’m asking for is unlimited access and modification ability to multiple projects at the same time, so if I need to add audio to project A then go back to work on project B, then show the approving producer project C, make a few frame adjustments to project C as requested, then go back to project B, I can do all of this by clicking the sequences that I have open (from project A, B, and C, all different projects), and not have to close project A, to work on B, then close B to add audio to A, then close A to go back to B, then approving producer calls and wants to see C, close B, open C, make edits, close C, open B continue working, etc. (all day long) It’s like my kid who’s going in and out, in and out, in and out of the back door, and each time he goes in and out, the screen door slams shut, WHACK!
    -bh
  • Jerry Wise
    December 3, 2014 at 6:18 pm
    I agree. I do the same workflow. working on project A….open B to change a text and output an mp4 for client approval…go back to project A….etc. all day long.
    another thing that irks me…in fcp7 you can import clips etc. to the browser..use them in your project…toss them away and keep a clean work area and still they are linked to your timeline..premiere cant do that. if you toss away your clips the link is lost to your timeline.
    there’s a lot to be done to make premiere more editor friendly.
    just saying….
  • Mitch Jordan
    December 3, 2014 at 6:27 pm
    I agree. Often, I have our CEO bop in to approve a spot and he doesn’t like to wait while Premiere loads the project and all the clips. However, if I leave the spot up, he may not come in for hours and I can’t do anything else. In FCP 7, I just left that project open in the background.
  • Bryce Hoover
    YES!! 1000x YES! on the tossing of clips.
    That drives me nuts too!
    -bh
  • Bryce Hoover
    December 3, 2014 at 6:28 pm
    Glad I’m not alone. That’s exactly the situation I’m talking about.
    -bh
  • Kevin Monahan
    December 3, 2014 at 8:41 pm
    Hello Bryce,
    [Bryce Hoover] “However… that work around doesn’t allow for changes to the second project sequence that I’ve opened in the Media Browser, it’s read-only and it’s only viewable in the source window”
    Yes, that’s correct.
    It sounds like if you did have access to write changes to that sequence from the editor’s project (perhaps through a lock and unlock mechanism), then what you want do might work out for you. I hope that’s the way you worded your feature request.
    “Make it open more than one project just like FCP” probably won’t be as helpful as you have to take into consideration how Premiere Pro is approaching the issue so far. Hope that makes sense.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Jerry Wise
    December 3, 2014 at 9:22 pm
    don’t get me started…there are tons of other things they need to do to make premiere a world class editing system.
    like…put crop in the motion tab…like fcp7.
    make adjusting audio levels easier..like 7.
    make track matte key track or not track with a button click. like 7.
    make the cursor skinnier. it’s too fat.
    make track height smaller. (I use 30 to 40 tracks..the smaller the better.)
    make a dissolve or wipe able to be dragged to other clips.
    make a dissolve at the end of a clip centered or start or end..like 7
    make page turn effect better..it’s cheap looking. I use page turns all the time…had to buy Boris to get a great page turn.
    improve wipes.
    spend a little time and money giving the many editors transitioning to premiere some better tools.
    I will have to say that the ultra key is pretty good.
  • Kevin Monahan
    December 3, 2014 at 11:32 pm
    Hi Jerry,
    [jerry wise] “spend a little time and money giving the many editors transitioning to premiere some better tools.”
    We’ve done a lot of that. I’m sorry you have not noticed.
    You know, we can’t make Premiere Pro into FCP 7 in every instance (nor would you want to). You have to take into consideration the existing architecture of Premiere Pro, for example.
    There are also a ton of things that Premiere Pro does a whole lot better than FCP 7.
    That said, some of your suggestions are valid. However, the only way the team will ever get these suggestions is by filing a feature request here: https://adobe.ly/feature_request
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Bryce Hoover
    December 4, 2014 at 3:07 pm
    Kevin,
    “read-only and it’s only viewable in the source window”
    Yes, that’s correct. “
    thanks for clarifying.
    “It sounds like if you did have access to write changes to that sequence from the editor’s project (perhaps through a lock and unlock mechanism), then what you want do might work out for you”
    I’m not sure how I worded the request, though I did try to refrain from saying something to the effect of please clone FCP, but it’s really hard to describe a function that didn’t exist until FCP without mentioning FCP…
    I simply want the ability to have several projects open, with all the abilities that are native to having just one open (i.e. full access read/write). This ability didn’t exist in Avid-land or in any other NLE (as far as I know). FCP opened the door to it and what a revolution it’s been to my workflow and to many of us.
    “take into consideration how Premiere Pro is approaching the issue so far.”
    I have taken this into consideration, that’s why I’m asking for this feature. The approach, as it is now, is handicapping to many. It’s taking an ability that many of us moving to PP rely on, and telling us we can’t have it. I’m unclear on the approach Adobe is taking, is it one of safety at the expense of functionality?
    Protecting projects while limiting workflows and degrading productivity?
    To me, protecting the integrity of a project is the job of whomever designs the individual workflow for each situation. I can say that because we’ve done it and we’ve not had a single issue in 5 years, with 2 finishing editors and 9 producer/editors all slinging stuff around. It seems Adobe is wanting to protect our projects, which I can appreciate, but it’s very limiting and burdensome to open and close, open and close, open and close, open and close, open and close, all day, every day.
    So far, I’m happy with PP CC, with the exception being this HUGE sink hole we’ve been discussing.
    -bh
