Activity Forums Adobe After Effects Adobe OUTPUT render malfunction
  • Adobe OUTPUT render malfunction
    Posted by Eric Budinsky on August 27, 2011 at 3:55 am
    Background information – I recorded a full screen game with fraps at 60 FPS, full resolution. Took that, imported it into after effects. The preview in after effects plays smoothly and perfectly.
    Problem – I render the video and when I try to play the video, it plays choppy, then an error message pops up saying — SEEKING FUNCTIONALITY MAY BE LIMITED THIS FILE APPEARS TO BE CORRUPTED. SEEKING MAY BE LIMITED OR BEHAVE UNEXPECTEDLY. I thought this was a problem with the video playback software (divx)– But it cant be because I watch movies with no problem at all, not to mention that the FRAPS recorded footage was in divx, and it played well. Its only when I take said divx footage into after effects, and render it, that it plays a choppy divx footage. I tried rendering it in avi format as well, I tried a bunch of different formats actually. They all turned out choppy.
    I made sure that the composition render was 60 frames as the recorded footage was in 60 frames.
    I really hope I dont have to do a full system restore…
    Rousselos Aravantinos replied 15 years ago 2 Members · 1 Reply
  • Rousselos Aravantinos
    August 27, 2011 at 10:18 pm
    I think fraps installs a codec which is suitable for it’s needs.
    so why divx?
    Using Divx files directly into AE sounds like risky.
    You Should always use/convert any web/source material into a more pro file type and then render your composite as uncompressed
    [if its possible ]
    I’d recommend you to render always in the best possible pro file format such as tif, dpx sequence.
    This way you will prevent to get a crash / re-render from scratch.
    Plus you will b able to evaluate your work whilst rendering in frames.
    ONCE U HAPPY use a converter to deliver the final product.
    so try to convert the Fraps video in frames Sequence First.
