Activity Forums Adobe Premiere Pro Adobe Media Encoder Freezes CS4 Magic Bullet Looks
  • Adobe Media Encoder Freezes CS4 Magic Bullet Looks
    Posted by George Labb on September 18, 2010 at 1:38 am
    Hi.
    After over 12 hours of trying every fix possible to get Adobe Media Encoder to Encode my rendered Adobe Premier Project to which I have applied Magic Bullet looks. I still have had no luck. It applys, renders and plays back fine within Premiere Pro CS4, I only have the problem when I go to Media Encoder to export the file, it just completly stalls
    I am using Magic Bullet Looks 1.3 for Adobe CS4
    I have also tried the following with 1.2 Magic Bullet Looks
    -I have taken magic bullet looks from common plugin folder and placed it directly in the premiere specifc plugin file.
    -I have unistalled magic bullet looks and tried installing directly to the premiere specific plugin file.
    -I have tried placing magic bullet looks in both premiere specific and media encoder specific plugin files
    – I have tried all this in administrator account aswell.
    – I have tried the adobe premiere dynamiclink shorcut trick as well.
    The only succes I have had in getting adobe media encoder to work with out stalling on the file is when I completly remove Magic Bullet Looks.
    It is obvious Magic Bullet Looks is causing this problem, any possible fixies would be greatly appreciated.
    I am trying to convert the file a high qulaity NTSC DV h.264. I have also tried various other file types
    I have adobe media encoder CS4 version 4.2.00.6
    And Premiere CS4 4.2.1
    Any suggestions, would be greatly appreciated!
    Cheers,
    George.
    Bruce Jones replied 15 years, 9 months ago 3 Members · 3 Replies
  • George Labb
    September 19, 2010 at 2:00 am
    Ive been thinking about the problems causing Adobe Media Encoder to stall when decoding Adobe Premiere projects with Magic Bullet Looks applied.
    I think it has something to do with the way in which Adobe Media Encoder reads the plug – in. Any ideas of where I can place it in order for AME to read the plug – in and be able to process the file, without stalling.
    As soon as I unistall Magic Bullet Looks, AME processes the Adobe Premiere Project perfectly.
  • Jody Schiesser
    November 19, 2010 at 3:04 am
    It sure would be nice to know the answer to this one. I have the same problem at the moment.
  • Bruce Jones
    November 22, 2010 at 9:14 pm
    I have this problem too. It worked once recently, to my surprise, and I’m trying to determine the problem.
