Activity Forums Adobe Premiere Pro Adobe Media Encoder Does Not Completely Encode File
  • Adobe Media Encoder Does Not Completely Encode File
    Posted by Ricky Pak on May 8, 2010 at 10:52 pm
    I encoded .avi files to mp4, but sometimes it will not completely encode the files. Say I have a 10 minute file, it will encode only 2 minutes of it and says encoding finish. I’ve tried Adobe Media Encoder CS4 and CS5 but both produce same results. What’s the matter with this program? I use AVS Video Converter instead and it encodes files completely.
    Jonathan Berry replied 15 years, 5 months ago 3 Members · 3 Replies
  • Mike Velte
    May 9, 2010 at 10:35 am
    Could you have the work area bar over just part of your timeline?
  • Ricky Pak
    May 9, 2010 at 1:33 pm
    that cannot be because after i add the file to queue, i don’t even go into settings to adjust anything. In CS5, I mouse over the filename from the queue, some files do not show the full lenght of the video, it gets shorten for some reason.
  • Jonathan Berry
    April 18, 2011 at 7:43 pm
    Did you ever find an answer for this? My video is 30 mins and AME is only encoding the first 29 seconds.
