Activity Forums Adobe Encore DVD Adobe Encore CS5 – Blu Ray 24p PAL
  • Adobe Encore CS5 – Blu Ray 24p PAL
    Posted by Doyle Hooper on June 28, 2011 at 11:00 pm
    I’m trying to create a 24p PAL Blu Ray. My production was shot 24fps and mastered 24p.
    Unfortunately the only option in Encore for 24p is NTSC. Ideally I’d like to have it as PAL.
    I was unaware that Blu Rays were PAL or NTSC. I thought the regions were either A, B or C.
    Any advice or suggestions would be great.
    Thanks.
    Daniel Ludwig replied 15 years, 2 months ago 2 Members · 3 Replies
  • Daniel Ludwig
    June 29, 2011 at 9:59 am
    Hey Doyle,
    1080p24 is a part of BD-specs that felt under the order of NTSC.
    BD could contain the following formats (all at the same time):
    – 1080p23.98, 1080p24, 1080i50, 1080i60
    – 720p50, 720p60
    – 720x576i (PAL)
    – 720x480i (NTSC)
    it´s different what you might know from DVD, where you can have only PAL OR NTSC.
    but be awared that int. BD-players wont play 25/50fps as this is only mandatory for countries that broadcast with 25/50fps.
    so best way to go is 1080p23.98 or 1080p24 if you would like to create an int. production.
    encore is doing it a bit different as the general standard is, but you must live with that.
    region code A, B, C is only available if you create a BDCMF for replication.
    cheers
    danny
  • Doyle Hooper
    June 29, 2011 at 11:14 am
    Hi Danny,
    Thanks for your advice.
    I think my confusion arose when I had to select NTSC or PAL when beginning the project. I assume an NTSC 24p project is the best choice for an int. production?
    Doyle
  • Daniel Ludwig
    July 3, 2011 at 9:11 pm
    yes, if you would like to create an international BD-project you can choose:
    1080p23.98, 1080p24 or 1080i30(29.98)
    cheers
    danny
