Activity › Forums › Adobe Encore DVD › Adobe Encore Blu-ray Authoring Error
Posted by Vinay Tiwari on August 25, 2009 at 6:55 pmChecking the project gives no error. But during Build when transcoding transcoding Following Error Comes
Blu-ray Object;
“Movie”,Error;”device error”,Code “2”, Note”Too many streams of PG stream in Clip”(Spec Table 9-3,Annex B) Thankx in advance
Jon Geddes replied 17 years, 1 month ago 2 Members · 4 Replies -
Jon Geddes
August 26, 2009 at 3:19 amAre you having Encore transcode the main video, or did you already transcode it. What type of file did you import into encore and what settings were used to compress it? What about the audio? What format are you using and how many audio tracks do you have?
Jon Geddes
http://www.precomposed.com -
Vinay Tiwari
August 26, 2009 at 4:33 amYes Encore CS4 transcodes the main video> I imported an Avi file in Encore
It was captured using cineform codec.My Blu-ray Specs are PAl ,1920X1080, codec Mpeg-2, Frame rate 25.
Maximum Audio Video bit rate 15 Mbps
Audio Transcoding PCM
Player Adobe Player
Audio is stereo. It imports with the video.
Export Setting is
1920x1080i 25 High Quality
Profile Main, Level high, bitrate encoding VBR 2pass, gop M frame 3 , n frame 12
In Audio – Audio Format PCM, 16 bit stereo -
Vinay Tiwari
August 26, 2009 at 4:56 amI am using Adobe Encore CS4
Yes Encore transcodes the main video. The imported video is in avi format.
The compression setting for the same are
Project Setttings
Authoring Mode blu-ray
Seetings PAL,1920×1080, Mpeg-2,frame rate 25
Maximum Audio/video bitrate 15.0 Mbps
Player Adobe PlayerExport Settings
video
1920x1080i,25,high quality
video quality 5,
Profile main
level high
bitrate encoding VBR,2 Pass
Min bitrate 1.5, target 25, max 30
gop m frame 3, nframe 12
Audio
PCM , Output channel Stereo, Sample 16bit
Frequency 48khz -
Jon Geddes
August 26, 2009 at 3:01 pmHmm, nothing jumps out as being abnormal except for the fact you are using PCM audio. Try using ac3 and see if that makes any difference. If that doesn’t work, I would try h264 encoding for the video. It will take much longer to encode, but look much better. You don’t have to change the authoring mode, just change the transcode settings for the asset.
Jon Geddes
