Adobe CS5
I have recently upgraded from Adobe Premiere CS3 to CS5. With my old system, I used the Matrox Software to export to tape and enable an external monitor. With the new system, I planned to rely on firewire, however CS5 will not export to tape and hence will not give me use of the external monitor.
I capture via firewire but cannot export. The software starts the DV deck and even lays down time code during the export process, but no video or audio passes through.
I have called Adobe Tech Support dozens of times and have received absolutely no help. Can anyone suggest a way to fix or get around this?Thanks,
Joe Moore
Raceline Productions, Inc.
