Activity Forums Adobe Photoshop adobe – batch converting?
  • adobe – batch converting?
    Posted by Mali on August 8, 2005 at 5:45 pm
    how to specify size in doing batch converting?
    where to specify?
    and
    how to specify size ?
    i start with 27″ x something,
    how to reduce to 4×6″
    help!
    thanks,
    mali
    Jeff Cochran replied 21 years, 1 month ago 3 Members · 6 Replies
  • Jeff Cochran
    August 8, 2005 at 6:00 pm
    When writing your script, go to image pull down> image size
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • Mali
    August 8, 2005 at 6:13 pm
    But how do I write a script which will automatically
    change the size of a BATCH of photos?
  • Amalia
    August 8, 2005 at 6:22 pm
    let me add – in Photoshop CS. Thanks.
  • Jeff Cochran
    August 8, 2005 at 6:33 pm
    When writing your script, use image size to change the size. you can change size by inches, percentage or pixels.
    The change in size will be written into the script and will be applied to all images you batch with this script
    Jeff Cochran
  • Amalia
    August 8, 2005 at 7:00 pm
    Sorry but how do I write a script?
  • Jeff Cochran
    August 9, 2005 at 4:02 am
    Under the window pull down>Actions
    Create a folder, then start recording. Every action you take will be recorded. Then under file>automate> batch. You can select the script you created to apply to a large number of images
    Jeff Cochran
