Activity Forums Adobe Audition adobe auditon causes error directly at start up
  • adobe auditon causes error directly at start up
    Posted by Humphrey on December 24, 2005 at 4:46 am
    Hi all,
    i got 2 PCs. On PC 1 i had the same problem, i always received this message after installing adobe audition (adobe auditon causes error) and the prog was closed. I tried to install similar progs but they werent good enough. I gave up back then and after 3 months i treid again and it suddenly worked. Unfortunately i dont know why.
    Now i got the same problem on my 2nd PC. I dont have no idea what to do, i tried to remove some audio codecs but no success.
    does anyone have any suggestions? thank you
    Willie Toth replied 20 years, 8 months ago 2 Members · 3 Replies
  • Willie Toth
    December 24, 2005 at 3:06 pm
    Two different computers and the same problem would lead me to believe the disk may be suspect … What are the spec’s on your computers …….. WILLIE
  • Humphrey
    December 27, 2005 at 4:24 am
    other progs like audacity and cool edit 2000 worked.
    i had a codec package installed and removed it. after that adobe worked. i installed another codec pack and it still worked.
    now i probably got a hardware problem. i run win2k, a pentium 500 and 250MB working memory. after the first 10 seconds i start recording a tape(thats the point when the windows updates theres a kind of electric hiss which appears sometimes durin a track.
    could it be that my pc is just to slow? when i listen to an audio cd on my pc cd drive theres also sometimes an electric noise, but not when i listen top mp3s from my hard disc.
    greeting
    humphrey
  • Willie Toth
    December 27, 2005 at 12:47 pm
    Dude,
    You need a serious update on your computer … Win 2000 kind of sucked as an operating system … I would go back to the older programs until you can get a better system together … WILLIE
