Activity › Forums › Adobe Audition › Adobe Audition in CS5.5 on a Mac re: editing a multi trac mix dilemma…
  • Adobe Audition in CS5.5 on a Mac re: editing a multi trac mix dilemma…
    Posted by Bruce Klein on October 1, 2013 at 1:28 pm
    I did a 2 camera multi cam edit and left the audio track active and it has broken it into clips along with the video. Can I sound edit the entire sequence in Audition?
    Also when I try to save the new file in PPRO it doesn’t show up as a separate file so I can revert back to it if I screw up…
    Also getting it back to premiere pro in its edited state is a problem…
    I looked up the version of Audition and it is 4.0…
    Is there a comprehensive tutorial somewhere or a manual available somewhere?
    I found a video tutorial Premiere Pro: Sweetening Audio with Parametric EQ but it looks like it is a PC version…
    Any insight would be helpful,
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 2 Terabyte external drives also.
    Thanks in advance for your help.
    Bruce
    Bruce Klein replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
