Activity › Forums › Adobe Audition › Adobe Audition Compatible with fcp x?
  • Adobe Audition Compatible with fcp x?
    Posted by Daniele Zurbrugg on August 21, 2012 at 8:34 pm
    I was considering buying Adobe Audition for sound work, but I use final cut pro x. Are there systems compatible? What steps would I have to take to get them to work together? Thank you.
    Angelo Lorenzo replied 14 years, 1 month ago 2 Members · 1 Reply
  • Angelo Lorenzo
    August 23, 2012 at 7:30 pm
    If Final Cut X can export OMF files then Audition should work without an issue.
    OMF is an interchange format used by ProTools and you can create self contained files (files that hold all your audio clips, I think there is a 4gig size limit) or a reference file that point to all the audio files and contains the audio mix.
    I’ve had no issue going between Premiere, Audition, and Protools with OMF, so I would be confident in saying that Final Cut X can do the same if it exports that format.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
