Activity Forums Adobe After Effects Expressions Adobe after effects scripting
  • ayat fatima
    November 7, 2020 at 6:56 am
    It is still giving error of “undefined is not an object” at second line..☹
  • ayat fatima
    November 7, 2020 at 1:16 pm
    var currentProject = (app.project) ? app.project: app.newProject();
    var compSettings = cs = [1280, 720, 1, 10, 24];
    var defaultCompName = “Demo”;
    var currentComp = (currentProject.activeItem) ? currentProject.activeItem: currentProject.items.addComp(defaultCompName, cs[0], cs[1], cs[2], cs[3], cs[4]);
    currentComp.openInViewer();
    var backgroundLayer1 = currentComp.layers.addSolid([93, 5, 2], “Background”, cs[0], cs[1], cs[2]);
    var mytextLayer = currentComp.layers.addText(“Bubble Sort\nSimple sorting algorithm\nComparison-based algorithm\nComparison of adajacen elements\nSwapped if they are in wrong order\nNo swapping if the order is true”);
    var textProperty = mytextLayer.property(“Source Text”);
    var textPropertyValue = textProperty.value;
    textPropertyValue.resetCharStyle();
    textPropertyValue.fontSize = 50;
    textPropertyValue.fillColor = [1, 0, 0];
    textPropertyValue.justification = ParagraphJustification.CENTER_JUSTIFY;
    textProperty.setValue(textPropertyValue);
    app.endUndoGroup();
    above code is working… But I’m unable to create more layers working at specified time or writing text letter by letter.
    can you please tell me that how is it possible in the above syntax.
  • Brendon Murphy
    November 7, 2020 at 7:48 pm
    The script I gave you will only work if there is already an active composition with a layer inside.
    To answer your other question, you could add this line to your code to add a new text element and set the inPoint to 1 sec:
    currentComp.layers.addText("New Text").inPoint = 1;
    Also, app.endUndoGroup(); should come at the very end, but only if you’ve done this at the beginning:
    app.beginUndoGroup("Name of your undo here.");
  • ayat fatima
    November 8, 2020 at 1:14 am
    Thank You so much it has helped me a lot.
  • ayat fatima
    November 10, 2020 at 7:46 am
    HHow can I set the position of a shape in shape layer… And how is it possible to combine more than one comps in the main comp
  • ayat fatima
    November 12, 2020 at 10:42 am
    // Adding shape layer for the circles
    var shapeLayer = currentComp.layers.addShape();
    // Adding circle shapes group
    var shapeGroup = shapeLayer.property(“Contents”).addProperty(“ADBE Vector Group”);
    createEllipse(shapeGroup, 200);
    createEllipse(shapeGroup, 400);
    // Adding black stroke to the shapes
    var stroke = shapeGroup.property(“Contents”)
    .addProperty(“ADBE Vector Graphic – Stroke”)
    .property(“Color”).setValue([0, 0, 0]);
    function createEllipse(shapeGroup, size) {
    var ellipse = shapeGroup.property(“Contents”).addProperty(“ADBE Vector Shape – Ellipse”);
    var ellipseSize = ellipse.property(“Size”).setValue([size,size]);
  • ayat fatima
    November 12, 2020 at 10:43 am
    In this code how can i change the position of shape..
Page 2 of 2
