Activity › Forums › Adobe After Effects › Adobe After Effects – render output – h.264 – passes, passes everywhere…
Posted by Bryan Fury on November 7, 2014 at 3:52 pmGreetings,
I’m kind of newbie what about after effects, I googled for few hours, but never found answer to my question.
My question is very simple, how do I rise number of passes, either at CBR or VBR while rendering h.264 file from my AAE?
Thank You!
Kind regards
Bryan
John Cuevas replied 11 years, 10 months ago 2 Members · 13 Replies -
John Cuevas
November 7, 2014 at 6:16 pmYou can’t. Either create an uncompressed master, or just import the comp directly into Adobe Media Encoder and do a multipass render there.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Bryan Fury
November 7, 2014 at 9:08 pmAnd one more question, when I export h.264, it names the file mp4 in the queue and everywhere, but when it exports it it’s m4v and I cannot play it anywhere. Please advise :/
John Cuevas
November 7, 2014 at 9:42 pmStrange, the only time I get m4v files is if I’m creating a DVD. Are you using an H.264 preset, which one, and if not do a screen shot of your settings and post here(3rd to last icon, remember to copy embed code and post it in your reply)
Bryan Fury
November 7, 2014 at 10:26 pm -
John Cuevas
November 8, 2014 at 1:32 amClick the multiplexer tab and make sure it’s set to mp4 and not none, none will create an m4v file. If that doesn’t
export your preset and upload it here, if I can install it(I have cs6), I see if I can figure out the problem.
Bryan Fury
November 8, 2014 at 10:35 amGreetings,
Thank You for Your further will to help me. I’m attaching my profile. My multiplexer is set to mp4 and it still exports m4a. I’ll try to create my own profile from some of the existing presets and rewrite it, or save it as new as next step,
Thank You!
Kind regards
Bryan
John Cuevas
November 8, 2014 at 12:50 pmI just ran two test’s using your preset—once importing a master directly into AME, then rendering a AE composition in AME and both time got the desired mp4. Your settings work fine for me.
Try importing a different video in media encoder and see if that spits out a m4v file or mp4. If it’s an mp4, then you might have an issue with your source file. What source file are you trying to encode?
Bryan Fury
November 8, 2014 at 1:52 pm -
Bryan Fury
November 8, 2014 at 2:02 pmUpdate:
When I use system presets, everything works fine, except I cannot modify anything,
When I create my own preset, it’s always m4v :/
Bryan
