Activity Forums Adobe After Effects Adobe After Effects
  • Adobe After Effects
    Posted by Ehimare Ojefua on February 6, 2006 at 8:23 pm
    Hello everyone,
    I’ve created a “speaker” in photoshop and imported the file into
    AE. I then an audio track that I want to sync up. I converted the track to keyframes,
    dropped down the “effects” triangle to reveal the right left and both channels. I then
    grabbed the whip from the “scale” of the speaker layer. I then dragged it to the amplitude
    layer in “both channels” and set the expression to *5. What I get is the scale up is too BIG and
    the scale down is two small. Is there a way to adjust the size of the scale in the frames.
    By the way the tracks syncs up perfectly but looks crazy when it is played.
    Andrew Kramer replied 20 years, 7 months ago 3 Members · 2 Replies
  • Chris Smith
    February 6, 2006 at 11:21 pm
    And you’ve tried smaller values than a multiple of 5?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Andrew Kramer
    what happens if you lower the multiplyer.
    also you can make the scale effect smaller then use a null object(link the layer to it) to scale the down beat to be at the scale you want for the small state then the large state should still be relative in size.
