Activity › Forums › Adobe Premiere Pro › Adobe 2.0 audio should I upgrade??? or pass…..
Joe Edwards replied 20 years, 5 months ago 9 Members · 24 Replies
Steve Spaw
April 1, 2006 at 3:22 amYou have all missed one of the best new features in 2.0.
You can now do a fill left/right in the track mixer.
Just setup track 1 to fill left and track 2 to fill right.
Then place the clip audio in the track that you want to use (or both).It really works well
Steve
Tim Kolb
April 1, 2006 at 5:17 am[Steve Spaw] “You have all missed one of the best new features in 2.0.
Then place the clip audio in the track that you want to use (or both).”No question that it’s a nice feature, but you’re still monkeying with stereo audio and trying to make it work like mono. As a workflow, I find it’s easier to simply make it all mono and be done with it…the track mixer method still requires a copy/paste of each and every audio clip if you want both tracks, but intend to mix them separately.
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Norman Lafranchi
April 1, 2006 at 6:29 pmYou should be good to go with that system. You may want to bump your RAM to 2 GB. You’ll need a firewire card if your computer doesn’t have it built in (<$40). Also, you may want to add another hard drive, it's nice to have a dedicated drive for audio, you're performance will improve a lot. (Because then the single media drive isn't skipping around trying to play multiple tracks of audio and video at the same time). It's not a must, though.
Joe Edwards
April 9, 2006 at 6:36 amI didn’t follow all this closely, but you can reimport a file and set Source Channel Mapping on that instance for additional uses.
-j
