Activity Forums Adobe After Effects Adjustment Layer Stack Issue
  • Adjustment Layer Stack Issue
    Posted by Nithish Kumar on July 15, 2018 at 1:17 pm
    So i wanna create this connected dots effect and in the process i had to add a common adjustment layer to add a Fast blur and a simple choker to create a fluidy effect.
    But the thing is the beam effect is also getting blurred and I’ve no other option than to push the beam layers to the top which i don’t want….So this is just a unsolved Bermuda Triangle where you need to restrict adjustment layers from affecting specific layer/s.
    Need your help guys !!!!
    Roei Tzoref replied 8 years, 1 month ago 2 Members · 3 Replies
  • Roei Tzoref
    July 15, 2018 at 3:03 pm
    [Nithish kumar] “need to restrict adjustment layers from affecting specific layer/s.”
    wouldn’t that be something… unfortunately that’s what adjustment layer is – affect ALL the layers underneath no exceptions. the common workaround is precomping the layers you want to affect by an effect and applying the effect to the precomp.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Nithish Kumar
    July 15, 2018 at 3:35 pm
    But the thing is i have the end points of the beam linked to the small dots via expression. Pre-comping it would break it….
  • Roei Tzoref
    July 15, 2018 at 3:55 pm
    [Nithish kumar] ” Pre-comping it would break it….”
    you can link layer properties between comps just change the code instead of:
    “thisComp.layer”
    to
    “comp(“Name of Comp”).layer”
    Roei Tzoref
