Activity Forums Adobe Premiere Pro Adjustment Layer Not Transfferring Properly from AE
  • Adjustment Layer Not Transfferring Properly from AE
    Posted by Anton Reed on August 29, 2010 at 7:20 pm
    Hi all,
    Was hoping to get some help with a AE -> PR issue. I’m working in After Effects and Premiere Pro CS4. I have an AE project that has some footage with adjustment layers and some solids that I go ahead and save as a Premiere project. When I open up the saved PR project in Premiere and load the sequence, my adjustment layers and solids have all turned into a block of pure white and no longer retain any of the effects applied to them in AE.
    Any ideas what may be casuing this and how it might be fixed? Thanks very much.
    Jon Barrie replied 16 years ago 2 Members · 1 Reply
  • Jon Barrie
    August 29, 2010 at 9:27 pm
    I think there has a been a misunderstanding with the way after effects and premiere pro work together here.
    Pr does not have adjustment layers or solids and masks like after effects so it won’t build them when asking AE to export as Pr project.
    You can either export the AE comp to a video file and import that to Pr or use dynamic link to import the AE comp to Pr.
    Hope this helps.
    – Jon Barrie
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
