Activity Forums VEGAS Pro adjusting track’s playback rate “live” in sony vegas 10.
  • adjusting track’s playback rate “live” in sony vegas 10.
    Posted by Mauricio Rodriguez on October 25, 2011 at 11:57 pm
    Hello, I was curious to find it out if it’s possible to adjust the playback rate of a track manually while it plays. It’s possible to change the rate, by moving the switch to the r/l located in the track controls, next to the clip, below automation and effects, but the changes aren’t recorded. Is there a way to alter the clip this way, through some recording method? All suggestions welcome, Thanks.
    John Rofrano replied 14 years, 10 months ago 2 Members · 1 Reply
  • John Rofrano
    October 26, 2011 at 12:06 am
    Look up “velocity envelope” in the help. You can add it to a clip and change it’s velocity. It will not affect the audio and doesn’t work at the track level but it will allow you to change the velocity over time.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
