Adjusting Title safe range – per DG FastChannel Request
Strange question, even our resident final cut certified training center didn’t have an answer… i’m not confident there is a solution.
We’ve been delivering through DG for some time now, and they want to move us to a new system. Upon trying to pass inspection, they are bouncing me on a title safe issue. Basically, my system shows the title within the bounds, but at DG dallas, its just outside the range. after submitting a screen shot to them, they said my ranges were set to 85% and they have there range set to 80%.
This doesn’t help a whole lot as no one seems to know where i can make this adjustment in Final Cut Pro. Does anyone know if there is a preference file i can edit, or a terminal command i can use to adjust the title safe overlay?
Could it be a format issue? were using ProRez HQ 4:2:2 progressive in 720 x 486 CCIR 601 40:27 , and then squeeze the output to DG specs: MPEG-2 single pass CBR in 720 x 512, Top Field, 4:2:2.
I’ve always though there scale conversion was strange but its what DG requires. Could this be causing the difference in title safe? Would you guys recommend we just edit in 720 x 512?
Strange, as i said before, we’ve been sending through them for a while, and this just became an issue today.
