Activity Forums Adobe After Effects Adjusting stroke size using slider control
  • Adjusting stroke size using slider control
    Posted by Wes Missing on July 13, 2020 at 6:27 pm
    Hi guys,
    This is my first post here, this forum has been very helpful to me throughout the years and I’m very grateful for it!
    Now that I can’t find the solution to my problem anywhere, I decided to post here and seek for any tips I can get.
    So basically, using keyframes I am animating a stroke width (using layer styles) which is applied on a composition.
    The animation is a simple stroke width scaling up from 1 to 50 and then back to 1 again.
    Using Slider Control (expression), I want to be able to adjust how much the stroke width scales up. For example, if I set the slider control to 100, I want this animation to go from 1 to 100 and then back to 1 again.
    Here is a video recording that might be helpful understanding what I’m asking for – https://streamable.com/9rz57u
    Thank you in advance for any suggestions.
    – Wes
    Richard Garabedain replied 6 years, 1 month ago 2 Members · 1 Reply
  • Richard Garabedain
    July 15, 2020 at 3:17 pm
    whats the problem…it looks like you know what your doing..its done right?
