Activity Forums Adobe Premiere Pro Adjusting Slide Transition
  • Adjusting Slide Transition
    Posted by Seth White on August 9, 2008 at 7:57 pm
    I want to make a picture slide from the right to the left. The default CS3 slide transition settings makes it slide from left to right.
    Tried adjusting every visible setting and the center but can’t figure it out.
    Is there an easy way to make a right to left slide transition?
    Robert William replied 18 years, 1 month ago 2 Members · 3 Replies
  • Robert William
    August 11, 2008 at 3:54 am
    Try going to effects & controls start “b” and end “a”
  • Seth White
    August 11, 2008 at 2:09 pm
    I don’t have the start a/start b window panes at the bottom of the video effects tab. They are missing completely. I see what they look like when I go into the help section. They’re not there under video effects.
    Is there a way to toggle them on or off? I can’t find any.
  • Robert William
    August 11, 2008 at 4:39 pm
    between your images when you add your transition.click on your transition then effects and controls tab beside your video preview and it says image “a” slides to image”b” change that b to a
