Activity Forums Adobe After Effects Adjusting only part of an image
  • Adjusting only part of an image
    Posted by Arica West on May 16, 2010 at 6:23 pm
    I need to essentially “blow out” a window, mimicking an extremely bright light shining through.
    Any ideas on the best way to accomplish this? I can do it simply using brightness adjustments but how do I only effect the window and not the rest of the image?
    Arica
    Todd Kopriva replied 16 years, 4 months ago 4 Members · 3 Replies
  • Tudor “ted” jelescu
    May 16, 2010 at 7:17 pm
    It depends on the image- it would help if we can see a still.
    One way is to duplicate the layer, mask the window on the top layer and apply effects as desired. You can also precomp the window layer and apply something like trapcode to simulate light rays coming through.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Charles Radville
    May 16, 2010 at 7:27 pm
    Make a duplicate of your layer with the window in it.
    Place it below the first layer.
    Mask the window in the lower layer(panes separately if you have them)
    Apply a hefty (40 or more bluriness) gausian blur to the masked layer
    Set the top unmasked layer’s transfer mode to overlay.
    Vwa Lah
  • Todd Kopriva
    May 16, 2010 at 8:56 pm
    You can also use a mask on an adjustment layer and apply effects to the adjustment layer.
    There’s a link to a tutorial that shows how to do this here: “Adjustment layers”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
