Activity Forums DaVinci Resolve Adjusting mask softness without effecting key-frames.
  • Adjusting mask softness without effecting key-frames.
    Posted by Steve Davies on August 25, 2012 at 8:27 am
    Hi, I have a window animated by key-frames and I need to adjust the window’s inside and outside softness. But the softness change is stored in the current key-frame, which means that it only lasts as long as the key-frame allows. Is there any way to set it ‘globally’.
    Thanks.
    Steve Davies replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
