Activity › Forums › Apple Final Cut Pro Legacy › adjusting gain level of clip before I open it
  • adjusting gain level of clip before I open it
    Posted by John Davidson on December 5, 2006 at 8:59 pm
    Hey herd,
    Anybody figured out a way to drop the audio level of a clip to say, -10, BEFORE you open it in the viewer? Better yet, drop the audio of about 100 clips at once? I work witn alot of sfx and music clips that blast my eardrum to heck and back in the viewer when compared to my sequence audio levels. I do lower then once opened, but every now and again I forget and kablam, my brains get rattled.
    Any ideas? I had hoped that opt/cmd/L would do it, but it doesn’t.
    Cheers,
    Neo
    Bret Williams replied 19 years, 10 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    December 5, 2006 at 9:58 pm
    OPen it in STPro, lower the volume and resave. I do this regularly to boost levels a bit from my sequence levels to DVD levels.
    Or just remember to lower the volume in the viewer before you play. I do that regularly too.
    Jeremy
  • John Davidson
    December 5, 2006 at 11:07 pm
    Thanks Jeremy, but perhaps I wasn’t clear. What I mean to say is, I have 1000+ music tracks that already loaded in FCP and I would like to select all of them and lower their playback level simultaneously – from within FCP’s browser. I think that taking it into STP would require reducing the master level permanently, which is overkill. I suppose what I’m asking for can’t be done….
  • Jeremy Garchow
    December 5, 2006 at 11:18 pm
    If all of your levels are consistent, you can copy and paste attributes, namely the audio levels. Adjust one track, copy it, paste the audio level attributes.
    Jeremy
  • Bret Williams
    December 6, 2006 at 5:22 am
    Can’t do it in the bin. Here’s a way…
    Make a sequence. Highlight all clips and drag them into the sequence. Select all in seq. Then press cmd+opt+L. Type -10. Delete all your clips in your bin (or create a new bin). Copy all clips in sequence. Paste into empty bin.
    Takes about 10 seconds depending on number of clips.
