Activity › Forums › Adobe After Effects › adjusting alignment of a compososition
  • adjusting alignment of a compososition
    Posted by Amelie Lim on August 28, 2014 at 7:12 am
    Good day! =)
    I have a simple question about AE.
    How do I move the composition to the left as shown in the image below?
    https://i61.tinypic.com/v42az8.jpg
    I can’t find the alignment settings in the composition. I can only adjust the size.
    Your response is appreciated.
    Amelie Lim replied 12 years ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    August 28, 2014 at 1:07 pm
    If you’re referring to moving the position of your comp (frame) in the comp panel, then all you need is to press and hold the space bar while right click-ing and moving your mouse in the Comp panel. This will move your comp frame around.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Amelie Lim
    September 1, 2014 at 5:17 am
    eyeball the position? I’m sorry but could you elaborate more on how to go about it?
