Activity › Forums › Apple Final Cut Pro Legacy › Adjust Volumes/DB Level of Audio Tracks in Bulk
  • Adjust Volumes/DB Level of Audio Tracks in Bulk
    Posted by Matthew Baamonde on January 19, 2011 at 2:24 am
    Hi everybody,
    I’m working with large batches of audio files (7,000+) in my FCP project, no video is involved. They are distributed by genre/category in separate bins and I’m required to adjust the volume parameter on all of them down -12 db.
    Is there a way to do this in bulk rather than clicking on every file and dropping it manually?
    There is a way to drop them in the sequencer and paste the attributes in bulk, but then I lose my bins and it’s just about the same amount of work anyway.
    Any ideas?
    Thank you!
    Paul Factora replied 14 years, 5 months ago 7 Members · 14 Replies
  • 14 Replies
  • Shane Ross
    January 19, 2011 at 6:40 am
    Select all the audio files you want to affect. Then type CONTROL ] to adjust down -3db. DO that 4 times to get -12db.
    Control [ goes up +3db
    Control- is -1db
    Control+ is +1db
    Shane
  • Peter Wiggins
    January 19, 2011 at 8:37 am
    I tend to prefer Command Alt L then adjust to the number.
    Peter
  • Matthew Baamonde
    January 19, 2011 at 6:21 pm
    Thank you guys. I will try this out now!
  • Matthew Baamonde
    January 19, 2011 at 7:23 pm
    Hey guys,
    I appreciate the help and I’ve tried it but when I highlight any more than one file, neither command does anything. Both your suggestions work for one file but nothing happens when more than one is selected…
    I’ll play with it… any ideas?
  • Shane Ross
    January 19, 2011 at 7:43 pm
    It should work. It works for me. Why it isn’t for you…mystery. Trash preferences and try again? This is how I do this…daily.
    Shane
  • Jon Smitherton
    January 19, 2011 at 8:31 pm
    Or if the all the audio is uniform, you can turn down the master by 12dB in the audio mixer.
    Jon
  • Jon Smitherton
    January 19, 2011 at 8:33 pm
    or set one level of a clip in time line, select others, option-V paste attributes of audio level.
    Jon
  • Richard Cooper
    January 20, 2011 at 12:02 am
    Hi Mathew,
    Are you trying to do what Shane said in on the clips in the time line or the browser bin? Won’t work in the Bin. The clips must all be on the timeline.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Matthew Baamonde
    January 20, 2011 at 12:05 am
    Ahh ok, that was the miscommunication.
    This is all in the bin. I have 7000+ tracks in separate bins so it would be just as much work to add those to the timeline as clicking each one and editing it manually.
    Unless I’m missing any other work arounds…
    Thank you!
  • Shane Ross
    January 20, 2011 at 12:07 am
    AHA! Good catch Richard!
    You can’t adjust anything to clips while they are in the browser. Can’t adjust audio, can’t add filters. Only in the Viewer or on the timeline/canvas.
    Shane
