Activity Forums VEGAS Pro Adjust the timing of several events simultaneously?
  • Adjust the timing of several events simultaneously?
    Posted by Vic Santiago on December 2, 2007 at 1:23 pm
    I made an opening title in vegas7 using several text media generators. I applied media edits, transitions, pan/crop, and track motion effects, etc. until I was satisfied with the results.
    The total running time comes out to about 34 seconds. I’d like to shorten the entire sequence to exactly 30 seconds.
    Is there a way I can quickly do this so that all the individual events in the time line are shortened proportionately, and thus get a total running time of 30 seconds?
    Thank you,
    Vic
    Vic Santiago replied 18 years, 9 months ago 2 Members · 2 Replies
  • Douglas Spotted eagle
    December 2, 2007 at 2:39 pm
    Select em’ all.
    Hit “G” for Group
    Hold CTRL and slide the right-most title to the left until you hit your 30 second mark.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Vic Santiago
    December 4, 2007 at 8:01 am
    Thanks Douglass, that solved the problem.
    After saving the intro veg file, I then opened the main video veg file, and dragged the intro veg file as a nested veg file.
    During playback however, the intro portion was not smooth, i.e., the pan/crop and track motion settings were “choppy” and seemed to “stutter”.
    Is this normal behaviour for nested files? Will the intro portion playback smoothly when I render the main file?
    Thanks again,
    Vic
