Activity Forums Adobe After Effects adjust audio levels from source quicktime files
  • adjust audio levels from source quicktime files
    Posted by Dan Denegre on October 17, 2012 at 11:21 pm
    I have 12 compositions with dozens and dozens of layers stemming from almost 60 different quicktime files. I’d like to quickly adjust the volume for the files to make sure there all (roughly) at the same level.
    Is this something I can do in AE, or is there a batch process with the qt files? I’d hate to have to drag each one into FCP or soundtrack pro to adjust and re-save the files.
    Any suggestions?
    Roland R. kahlenberg replied 13 years, 11 months ago 4 Members · 4 Replies
  • Mathew Fuller
    October 18, 2012 at 12:27 am
    Pres LL with layer selected quickly to bring up the waveform. Press L once to bring up keyframing.
    My Work:
    https://www.morecompletefx.com
  • John Cuevas
    October 18, 2012 at 12:03 pm
    You could take each composition and drag it on to the new comp button. Then use the audio tool or the stereo effect to adjust the level of the entire composition all at once. Press the “.” to preview audio the audio and you should be able to get everything to acceptable levels.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dan Denegre
    October 18, 2012 at 2:53 pm
    That could definitely work. I wound up just exporting all the segments I needed and I’ll only be raising the volumes on the ones that are too low. It’s not exactly a solution but I’ll get the job done at least…
  • Roland R. kahlenberg
    October 18, 2012 at 11:45 pm
    [Dave LaRonde] “It would be very cool if there were a Normalize Audio effect”
    I’m surprised Adobe Audition hasn’t been mentioned.
    Cheers
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
