Activity › Forums › Apple Final Cut Pro Legacy › adj a range of clips w Audio Mixer?
  • adj a range of clips w Audio Mixer?
    Posted by Paul Dougherty on March 22, 2011 at 9:16 pm
    Is there a way (as one would do with an Avid) set a range with in & out marks in a seq then set a level or pan (or plus/minus adjust) in the Audio Mixer to change a range of clips all at once?
    Paul
    Jeff Greenberg replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 22, 2011 at 10:07 pm
    You could select the clips (sorry – no in/out here) and use the Modify – Adjust Levels (and make sure it’s relative).
    Same concept – you could also use the Control [ ] and Control – = (for +-1 and +-3db)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
