Additive Dissolve disappears when rendered – multitrack video
Surfing Google and Creative Cow in desperate attempts to solve an additive dissolve problem that I am stuck with, no luck as yet – hope anyone has the answer?
2 video tracks, the shot of the upper one starts with start-on 4 frames additive dissolve which blends perfectly with the shot of the below track that started earlier – only while previewing!
When rendered or exported as QT movie, the previously nice looking additive dissolve turns into a simple cross dissolve with no signs of the additive flash with overexposed highlights that I was keen on achieving.
Problem is solved when I put both pieces onto the same track and add an additive dissolve in between the two shots – but I can’t believe everyone in the world cuts the material with additive dissolves using one track sequential approach only, no multitracking?
Appreciate any input on this, ladies and gents.
Maxim
