Activity › Forums › Apple Final Cut Pro Legacy › Adding Visual TC
Adding Visual TC
Posted by Richard Boddington on November 30, 2007 at 6:59 pmHi,
I need to add continuous visual TC to my edited project in FCP 4. And I need it to be in 24fps mode.
Any ideas on how I can do this?
Richard.Mathieu Marano replied 18 years, 9 months ago 6 Members · 14 Replies -
Walter Biscardi
November 30, 2007 at 7:16 pmEffects > Video Filters > Video > Timecode Reader
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Jeremy Garchow
November 30, 2007 at 8:16 pmActually, if you need it to be continuous, you want the timecode generator, not the timecode reader.
Jeremy
Richard Boddington
December 1, 2007 at 3:29 amO’Tay, any idea where that is? It’s not in the video menu.
R,
Shane Ross
December 1, 2007 at 3:43 amEnabling that option in the AJA Control Panel ONLY makes TC appear when you use AJA TV to output. It does not allow VIS TC export from within FCP.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Jeremy Garchow
December 1, 2007 at 3:44 amO’Tay. Good one.
It’s right where Walter said it was, it’s called Timecode Generator.
If you don’t see it, go to the Effects > Effect Availability Menu and make sure it’s set to ‘All Effects’
Jeremy
and for your viewing pleasure:
Rafael Amador
December 1, 2007 at 3:48 amYou can use the TC Reader or Generator.
The easiest way is that you nest your sequence and drop the TCReader (Filters>Video).
The TC will be based in the time base of your sequence, so if you need a TC based in 24Fps, you need to work in a 24Fps sequence.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Richard Boddington
December 1, 2007 at 3:49 amDang, I’m using FCP 4 and it’s not in the effects menu that I can see.
Jeremy Garchow
December 1, 2007 at 3:55 amOh. Yeah. I think it might have been called Timecode Print or something in FCP4.
Jeremy
Richard Boddington
December 1, 2007 at 3:59 amI have Time Code Print in the effects menu, this puts VTC on the shot I have selected.
But of course it goes back to zero every time there is a shot change. So this must be where the “nesting” comes in?
How do I “nest” the show? Does all the video need to be on the same track to nest it?
R,
