Activity › Forums › Apple Final Cut Pro Legacy › Adding Visual TC
Rafael Amador
December 1, 2007 at 4:18 amIts goes back to 000000 because you have drop the TC Generator. If you would have drop the TC Reader, you will get the original footage TC.
Nest and drop the TCR and you will get corresponding to the sequence TC.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Richard Boddington
December 1, 2007 at 4:23 amI think I’ll just get the post house to pull a dub from my master with VTC.
I have so many problems with this. I need to make the time base 24fps. When I go to make the change in FCP 4, the project just crashes, every time.
When I make the change in FCP 3, the time line dissapears, and becomes greyed out so I can’t bring it back.
So much grief….a dub will work better.
R, -
Rafael Amador
December 1, 2007 at 9:33 amYour software was the best few years ago. Instead of spending money with other company, upgrade.
Mathieu Marano
December 1, 2007 at 12:50 pmActually, with version 4 of the Kona Software, it now displays the timecode with FInal Cut on you external monitor.
