Activity Forums Maxon Cinema 4D Adding Video In Cinema 4D
  • Randy Johnson
    October 24, 2008 at 7:32 am
    Yep,
    load it into a material like you would a bit map. Then in the material editor you can adjust the timing from the Animation tab.
    When using it for ref. I would load it to the luminace…but it does’nt really matter.
    /Randy
  • Marc Daniel villarin
    October 24, 2008 at 8:06 am
    Thank you very much. Now I can animate my 3ds correctly!!
    Coolness.
    https://www.youtube.com/user/marcdanielvillarin
    Look on the Bright Side…
