adding video/ audio transition at end of clip
Hi all,
I’m an experienced AVID editor trying to master Final Cut Pro. I just found out that although it is possible to drag a dissolve at the end of a clip in the timeline, i cannot use the standard keyboard shortcut! I can use the standard keyboard shortcut to put a dissolve at the beginning af a clip or in between two clips, but not at the end of a clip.
Does anyone here know if this is by design, or a bug, or do am I overlooking something 🙂
I’m using the latest version FCP
