Activity Forums Apple Final Cut Pro Adding Transition to Text in Secondary Storyline
  • Adding Transition to Text in Secondary Storyline
    Posted by Sascha Engel on April 9, 2015 at 10:42 am
    I have a weird problem:
    When I have a text on the Secondary Storyline as Super over some images on the Primary Storyline,
    and I ad a transition to the Text layer, it effects the entire image, also the one on the Primary Storyline.
    How come?
    Ut’s a sudden bug?
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 11 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    April 9, 2015 at 11:56 am
    What transition?
  • Sascha Engel
    April 9, 2015 at 12:19 pm
    Ji Jeremy,
    Actually, I tried it with several ones. In this case is was mainly blurs & wooshes.
    Greetings,
    Sascha Engel
  • Nick Toth
    April 9, 2015 at 12:41 pm
    Some transitions are only made to work between clips. Some can be modified in Motion to work properly with titlesand some can’t. In Motion you have to turn off A or B depending on if you want an incoming or outgoing transition.
    anickt
  • Sascha Engel
    April 9, 2015 at 12:49 pm
    Thanx for the quick reply. Will try that!
    Once of the things, where I expected X to behave like 7. 😉
    Sascha Engel
  • Bret Williams
    April 9, 2015 at 1:33 pm
    When you have 7 layers stacked up and you want to slide or whoosh between them all, you’ll appreciate those transitions more.
  • Sascha Engel
    April 9, 2015 at 2:33 pm
    You are right, for that occasion it rocks, but I’d like to have a choice, and the fact that I cannont make it work stand alone only for the superimposed text layer really sucks.
    I ended up doing it in AE, since due to deadline patience was low.
    Sascha Engel
  • Nick Toth
    April 9, 2015 at 8:05 pm
    Try these. They are copies of other transitions modified specifically for text.
    8716_texttransitions.zip
    anickt
  • Sascha Engel
    April 10, 2015 at 5:39 am
    Thank you! Very generous of you!
