Activity › Forums › Apple Final Cut Pro Legacy › adding transition to clip and title
Posted by Jason Brown on August 24, 2009 at 5:45 pmHey Guys,
I have video with a title graphic that I want to transition. My workflow in AVID is to submaster the clip and title into one clip…then add transition.
In FCP, it won’t let me add transition to center…because it says I don’t have enough handles. Is this the best way to do this?
-Jason
David J. smolar replied 17 years, 1 month ago 3 Members · 6 Replies -
David Roth weiss
August 24, 2009 at 5:48 pmJust add the same transition on both the video and graphics tracks.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Jason Brown
August 25, 2009 at 1:11 amHey David,
That seems really inefficent, because you now have 2 effects to render…is nesting used at all in that way? Seems to limit me on handles when I nest…
What are some applications you’d select several tracks and nest them?
-Jason
David Roth weiss
August 25, 2009 at 1:18 amJason,
The problem is that nesting brings with it an entirely new set of potential issues. And, rendering transitions is no problem. I know it sound inefficient, but I find it’s just better to thrown ’em in the timeline and move on.
David Roth Weiss
Director/Editor
Jason Brown
August 25, 2009 at 1:34 amgood to know. That is how I’ve been working and it’s been a real struggle. That’s the best workflow in AVID, but not here I guess! 🙂
-Jason
One good shortcut to do same transition is to alt drag the effect, which in affect copies the exact clip…right? Is that your workflow?
David Roth weiss
August 25, 2009 at 2:28 amOn my keyboard it’s option + drag. And yes, that’s a good technique for copying transitions, clips, etc., etc.
David Roth Weiss
Director/Editor
David J. smolar
August 27, 2009 at 4:56 pmHi all. I’m thinking of another possible solution, if I may. You could choose a transition and double-click it to open it in an editor, then trim the transition’s handles in the Viewer so it’s shorter [or edit the transition from the default any way you wish].
With the transition open in the Viewer, in the top right corner of the Viewer you’ll see an icon of a hand over a transition icon. Click-drag that into the timeline to drop your now-customized transition between clips.
Oh, and after that, I’d click-drag the same icon into the Favorites bin in the Effects tab of the Browser, then rename it to remind yourself of the transition’s new parameters [“quicker dissolve”, “push slide 2 sec open”, etc.]. Then, anytime after that, if you want to duplicate that transition just the way you like it, you can grab it from that Favorites bin. Helps to streamline your workflow.
Good luck, Dave.
David J. Smolar
Preditor
Creative Video of Washington
creativevideo.com
inbetweenthings.com
