Activity › Forums › VEGAS Pro › Adding Transition Restores Deleted Frames
  • Adding Transition Restores Deleted Frames
    Posted by Derek Brennan on October 21, 2014 at 3:20 pm
    I am a novice user of Vegas Pro 12 and have run into a problem with transitions. When I delete about 5 frames at the end of a clip using the split function with Auto Ripple on, the transition between the two clips plays correctly. However when I apply a transition (NewBlue Titler Pro 3.0 ) the previously deleted 5 frames are restored.
    I would greatly appreciate any help to overcome this problem.
    Derek
    Derek Brennan replied 11 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
